I am having alot of problems with my pc.
To start it off, my computer froze, showed a blank red screen, and restarted when I was playing Overwatch.
Then when I got back to my computer, it crashed a couple minutes later with the error "memory fault". I booted my computer another time and it immediately showed the error "page fault in nonpaged area".
So after seeing those errors, I removed one of the ram sticks and then my PC started making the memory problem beep. I then moved the stick of ram (the one that was still in the pc) to another slot of the motherboard and it started working. Any ideas as to exactly what the problem here is?
https://linustechtips.com/topic/730234-please-help-me/
13 minutes ago, Droidbot said:
board ram slot is faulty or memory is faulty
to rule out memory being faulty run memtest with the one working slot on both dimms
i have already used the memory diagnostics built into windows and it says my memory is fine, is it not accurate?
also, should I do it with each stick of ram? and how many passes do you recommend I run it for?
also I wanted to add that this has happened many times before. I just switch the ram up in different slots or just reseat them and they start working for a couple days. then the problems starts again
https://linustechtips.com/topic/730234-please-help-me/#findComment-9280537
I'd say RMA the motherboard with whoever makes your board. RAM slots are faulty.
idk
https://linustechtips.com/topic/730234-please-help-me/#findComment-9280549
Run the tool "memtest" over night just to make sure its not the RAM.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/730234-please-help-me/#findComment-9280630
