I've had the worst computer for years now and finally saved up enough money to build my first pc. I'm quite young so im not 100 percent certain on the parts. This computer is going to be primarily used for gaming. Would love any suggestions/opinions please and thank you. Total cost: $2400
CPU: Intel core i5 7400 kabylake 3.0ghz 6mb
CPU Cooler:I'd-cooling frostflow 240l white led cpu liquid cooler
GPU: gigabyte gtx 1070 8gb gddr5
Motherboard: asus rog maximum ix hero lga1151 atx
Memory: consair 16gb kit(2x8gn) ddr4 vengeance lpx black c14 2400mhz
OS: samsung 850 evo series 2.5" 7mm 250gb ssd
Power Supply: consair rm750x 750w 80plus modular power supply
Fans: fractal design silent series r3 120mm cooling fan
Wireless:asus over-n15 300mbps wireless-n pcle adapter
Case: InWin 303 black mid tower case w/tempered glass side panel
I didn't add any of the led options etc just the main components. I can have a storage drive, optical drive and card reader also not sure if I should or not.
https://linustechtips.com/topic/729275-first-build/
You have a locked CPU with a Z270 motherbord, you need a unlocked one to OC (i5 7600K), or just save money with a B250/H270 motherboard. 750W is overkill, 500W is enough.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/729275-first-build/#findComment-9270736
you could try this out
PCPartPicker part list: https://au.pcpartpicker.com/list/dNbQhq
Price breakdown by merchant: https://au.pcpartpicker.com/list/dNbQhq/by_merchant/
CPU: Intel Core i5-7600K 3.8GHz Quad-Core Processor  ($338.00 @ Shopping Express)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($79.00 @ Centre Com)
Motherboard: MSI Z270 GAMING PRO CARBON ATX LGA1151 Motherboard  ($287.10 @ Skycomp Technology)
Memory: GeIL SUPER LUCE 16GB (2 x 8GB) DDR4-2400 Memory  ($99.00 @ PLE Computers)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($125.00 @ Centre Com)
Video Card: Asus GeForce GTX 1070 8GB Dual Series Video Card  ($590.21 @ Skycomp Technology)
Case: Inwin 303 White ATX Mid Tower Case  ($109.00 @ Mwave Australia)
Power Supply: Corsair RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($171.40 @ Skycomp Technology)
Total: $1798.71
Generated by PCPartPicker 2017-01-27 21:56 AEDT+1100
https://linustechtips.com/topic/729275-first-build/#findComment-9270750
1 minute ago, danzz67 said:
okay changed both, anything else?
Thank you heaps
What have you changed it to, post is the same. Try to use PCPart picker, much easier to plan with and read.
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/729275-first-build/#findComment-9270753
Total: $1798.71
actually at this price you may be able to squeeze a 1080 in there
https://linustechtips.com/topic/729275-first-build/#findComment-9270760
I'm using a Australia computer building site that has limited options (because I'm not confident enough to do it myself).
the motherboard options of that type are:
MSI Z270 PC MATE LGA1151 ATX
MSI H270 GAMING M3 LGA1151 ATX
MSI Z270 SLI PLUS LGA1151 ATX
With the CPU cooler I have only options of id-cooling and consair hydro range.
Everything else fits, sorry for the hassle.
https://linustechtips.com/topic/729275-first-build/#findComment-9270783
Although you'll be spending quite a lot more compared to if you were building it yourself, there's not wrong with it.
If you're going with a locked CPU the then H270 motherboard is perfectly fine but if you're going to use an unlocked CPU then either of those z270 motherboards are fine as well. To be fair, depending on the price difference between the 3 motherboards, you may as well go with a z270 motherboard as from what I've seen, the difference between a z270 and a h270 motherboard at the moment is like $5 :P
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/729275-first-build/#findComment-9270792
Yeah it is quite bit more but ahhhh. What would you recommend for the CPU cooler?
https://linustechtips.com/topic/729275-first-build/#findComment-9270806
I'd say corsair? It's because I've never heard of id-cooling before :/
https://linustechtips.com/topic/729275-first-build/#findComment-9270839
Find another site if the one you are looking at is very limited. Numerous online merchants offer custom build options.
https://linustechtips.com/topic/729275-first-build/#findComment-9270856
If your in Australia,
I'd try and use the Australian PC Part Picker, helped immensely when I was planning my 1st PC build.
Link is Below
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
https://linustechtips.com/topic/729275-first-build/#findComment-9271545
