2 minutes ago, Knawlege said:
I have a H100i v2 and whist installing the Intel back pate onto my mobo one of the plastic screws broke off.
Is its safe to install it with only three screws supporting it?
Try contacting Corsair to see if they are able to get you a replacement if you don't have all 4 points will will apply uneven pressure and poor cooling.
https://linustechtips.com/topic/729085-please-help/#findComment-9268934
You can use it short term fine, it's not going to blow up or anything, but I'd request a replacement as cooling won't be optimal given you won't be able to screw down in one corner.
System: Ryzen 7 5800X - Gigabyte X570 Aorus Master - Noctua D15S Chromax - 32GB 3600 RAM - EVGA Black 2080Ti
https://linustechtips.com/topic/729085-please-help/#findComment-9268941
