Alright so I was about to install windows on my brand new ssd with USB method
Right when I installed windows and it was verifying download It crashed and says it couldnt use the tool or something along those lines
I checked windows explorer and saw that name of my USB changed from Toshiba :E  to --> ESD-USB (E:)
and inside that usb there is only "autorun".
What did I do wrong and what am I supposed to do ?
GPU: GTX 1060 6GB
RAM: 16GB HyperX RAM
CPU: R5 3600
Motherboard: ASRock B450 Fatal1ty gaming K4
OS: Win 11 Pro 64-bit
Should I have pressed Upgrade this PC or press what i already have pressed "Create installation media for another PC "
GPU: GTX 1060 6GB
CPU: R5 3600
you need to select create installation media for another pc. Then you can skip the download part. maybe that is the problem
My Setup:
CPU: i7 4790 @3800 MHz, MB: MSI H87-G41, Grafik: Gigabyte GTX 1080TI, RAM: 2x 8GB DDR3 (1600), Storage: Samsung SSD 850 Evo
What do you mean i can skip it ? I am creating a bootable USB
GPU: GTX 1060 6GB
CPU: R5 3600
1 minute ago, srfortune said:
If your usb already has the autorun and ESD-USB label you should probably format the Flashdrive and re run the media creation tool .
How do I format USB ? any video on it?
GPU: GTX 1060 6GB
CPU: R5 3600
When you are in the menu of creating the USB Stick, doesn't it ask you if you want to update the installation or skip it? Maybe it was only when doing the upgrade...
Just format the USB Stick and try it again.
My Setup:
1 minute ago, RKRiley said:
right click in disk management or my computer > format
Change any of this ?
FAT32
Allocation unit size: 4096 bytes
GPU: GTX 1060 6GB
CPU: R5 3600
Should I change anything mentioned up ? while reformatting
GPU: GTX 1060 6GB
CPU: R5 3600
no keep the default. The Tool should format it anyway again
My Setup:
Alright, already done that it's downloading right now at 23%- *hoping everything goes well*
GPU: GTX 1060 6GB
CPU: R5 3600
My god...does any of you know the tool called RUFUS? Use that to make the USB it is reliable, fast and easy to use https://rufus.akeo.ie/
Specs:
PC:CASE: FD Define r6 | CPU:Intel Core i7-8700k | MB: MSI z370 PC Pro RAM: 32GB Corsair vengance LPX 3000 GPU: Asus rx 6900xt Tuf STORAGE: nand 500GB Samsung 970Evo plus ; Game Storage: 2TB Samsung 860QVO Storage: 2 x WD Green 4TB | PSU: Corsair RM850x | CPUCooler: Noctua NH-D15   DISPLAY: LG 27GL850
Do I install it the same way I would install with media cration tool ?
I will give it a shot if this fails on me this time
GPU: GTX 1060 6GB
CPU: R5 3600
You download the operating system image and than run this tool...on the tool you select your USB and the system image you downloaded. Than you select file system, and partition scheme and press start and wait that is it. You have the whole guide on their site...check it out you ll save yourself a lot of time and nerves using this
Specs:
When I did this a while ago, I had to download the media twice because the first time it got to 50%, failed with an error and I also had ESD-USB with just autorun.
It was Avira Antivirus blocking autorun on USB sticks. When I turned the setting to off, the Media Creation tool was able to successfully create a working Windows 10 install media.
Do you have something blocking autorun?
Yup it just got stuck on 50% created autorun and access got denied by avira
Like the moment you wrote that
what do I have to do ?
GPU: GTX 1060 6GB
CPU: R5 3600
2 minutes ago, Zagna said:
Turn off "Block autorun function"
I can't seem to find that exact tab I don't have antivirus Pro
GPU: GTX 1060 6GB
CPU: R5 3600
Can I just end task on Avira just so I can install it and that's it ?
GPU: GTX 1060 6GB
CPU: R5 3600
When you have main Avira window open, press F8 to open Configuration. There you can find it.
It doesn't do anything for me
GPU: GTX 1060 6GB
CPU: R5 3600
In the menu Extras, no Configuration? Or then in configuration is there an 'Expert Mode'?
Ok I found it, should it be checked or no ?
GPU: GTX 1060 6GB
CPU: R5 3600
