M.2 help 950 vs 960
Solved by Ensho,
960 Evo. Here is the Crystal Disk Mark of mine after the last firmware update and bios update for my motherboard:
Write speeds at times get close to 1800MB/s. I have the 500gb model, so your writes won't be quite as fast with the 250gb model, but it will still be plenty fast. The drive performs well and doesn't have any issues with thermal throttling..however I would recommend getting a PCIe x4 adapter card as doing so does reduce heat output as it gets better airflow. I have mine paired with the Asus Mini Hyper M.2 PCIe Adapter. Temp idles at 31c and gets around 50c under full load. If I install it on the mobo, it idles around 38c and under full load goes into the mid to upper 50s...close to 60c.
