So, with my current fan setup, I have two Corsair AF120 in exhaust, one AF120 mounted in the very bottom for intake for my GPU, and two Alphacool Eiswind 120 fans mounted to a radiator also as intake. I'm looking to replace these fans with quieter fans. The problem is, I don't know which fans to choose. I'm currently considering Noctua, Fractal Design's Venturi fans, or Corsair's ML fans. What do you guys think are the quietest and offer the best value on the dollar?
https://linustechtips.com/topic/728244-good-case-fans/
noctua's fans are great/
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/728244-good-case-fans/#findComment-9259527
best fan for the dollar... throw noctuas out. not even that quiet either... herd alot of good things about venturi fans, and some others are scyths but idk if you can stillfind them. i love the bequiet silent wings 3 but heir about $20 each. but best performance per dollar are probably gonna be your really cheap silent fans. sure they wont last as long but you cant beat the price
Tsubasa (The 7680x1440 beast): CPU: Intel i7 8086k | Cooler: Fully Custom Rigid Loop MOBO: Asus Z370-I ITX | GPU: Nvidia Titan Xp Star Wars | RAM: 32Gb 2x16gb Gskill Trident Z RGB | SSD: Samsung 1TB 970 Evo Nvme, 2TB Micron Sata SSD | Case: Fractal Design Nano S | PSU: Corsair SF600 With Full custom cables
https://linustechtips.com/topic/728244-good-case-fans/#findComment-9259530
I wonder sometimes if people praising Noctua fans even used them before lol. The performance is good, but they get loud just like any other fan at 12v.
If you want a good all rounder fan for price and quiet performance, get some Venturi fans.
https://linustechtips.com/topic/728244-good-case-fans/#findComment-9259591
I have 4 Corsair ML Pros (3 x 120mm intake + 1 x 140mm exhaust + Corsair H100i GTX w/ 2 x SP120mm in push at the top) in 1 build and 4 Corsair ML White LEDs (3 x 120mm intake + 1x 140mm exhaust + Corsair H100i V2 w/ 2 x SP120mm in push at top) in another build. I found the MLs to be pretty much silent, they never are at an RPM even while gaming or running any intensive programs that causes them to make noise. In the 2nd build, I'm using a Phanteks Enthoo Evolv TG Edition case which has basically no sound dampening foam because of the tempered glass on both sides and I still can't hear them. I personally haven't use Noctua's because I've heard they're loud af and they're pretty ugly tbh too. I like that the Corsair MLs have great performance and looks. I chose White LED ones for my 2nd build not just because of the cost but because I thought the soft white looked better than the lights on the HD series. I included a pic of my 2nd pc so you can see what they look like.
CPU: Intel i7-6700k | Motherboard: Asus Z170 Pro Gaming Aura | RAM: G.Skillz Ripjaws V Series 32GB DDR4 3200 (4 x 8GB) | GPU: EVGA GTX 1080 FTW Edition | Storage: Samsung 850 EVO 1TB SSD + Samsung 850 EVO 500GB SSD | PSU: EVGA Supernova P2 750W | Cooling: NZXT Kraken X62 | Case Fans: NZXT Aer RGB 120mm x 3 + NZXT Aer RGB 140mm | Case: Phanteks Enthoo Evolv TG Edition | Lights: NZXT Hue+ | Monitor: Asus ROG Swift PG279Q | Keyboard: Corsair K70 RGB LUX Mouse: Zowie EC2-A | DAC/AMP: Schiit Magni Uber + Schiit Modi Uber | Headphones: Sennhesier HD598 SE + Fostex T50RP Mk3 w/ Mayflower Mods | Mic: Antlion ModMic 5.0 | OS: Windows 10
https://linustechtips.com/topic/728244-good-case-fans/#findComment-9268477
