Audio switching
Solved by Naeaes,
Right-click on the speaker in the task bar and pick "Playback devices".
Right-click on the window and make sure both "show disabled" "show disconnected" are enabled.
Then make sure both HDMI and speakers are enabled and detected as plugged in.
Then right-click on speakers and enable both "set as default device" and "set as default communications device".
Save and exit.
Edit: Just to clarify, "speakers" can mean "headphones" depending on your other hardware, windows might not be able to differentiate between speakers and headphones, hence it calls everything "speakers". If instead you have "heaphones" visible in there, set that as your default.
