My corsair h100i gtx is in rma so i am using an intel stock cooler on my 6600K
When playing csgo max temp is 82*C
is that normal?
I just changed my motherboard to the Asus Aura RGB to
Insert   Dank   Signature   Here.
https://linustechtips.com/topic/727720-cpu-temps-wtf/
is that normal?
It's still ok. I mean it's not ideal but will do.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
https://linustechtips.com/topic/727720-cpu-temps-wtf/#findComment-9253256
is that normal?
I have the exact cooler and cpu. I am overclocked to 4.6GHz and my highest temperature ever is 50 degrees celcius. My average temp in a game like CS:GO is 45 degrees celcius. Whats your ambient temperature? (Temperature in your room)
Tech enthusiast and CS Student
https://linustechtips.com/topic/727720-cpu-temps-wtf/#findComment-9253317
if the thing is going up to max speed, i'd see it get 82°c on a stock intel cooler.
take in mind, the thermal output isnt load dependant, it's voltage dependant (and the chip pushes that up and down to adjust its clock appropriate to the load)
https://linustechtips.com/topic/727720-cpu-temps-wtf/#findComment-9253360
is that normal?
unfortunately yes that sounds about right
6600k is rated at 91Watts TDP
and theres a reason why intel doesnt include stock coolers with their K series chips these days.
Photography / Finance / Gaming
https://linustechtips.com/topic/727720-cpu-temps-wtf/#findComment-9253377
