10 minutes ago, Senpai Jenson said:
https://pcpartpicker.com/list/q8n8xY i got all my part but the cpu will i get the i5 6400 or i5 6500
Good power supply choice. I have that PSU and it's great. The cables are very stealthy, and the fan is inaudible.
I would change a few things among the remaining parts, though. Drop the Wi-Fi adapter and run an ethernet cable for better stability and consistency. I managed to fit in a GTX 1070, and it doesn't come to much more than your build + a 6500.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($188.89 @ OutletPC)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  ($46.99 @ SuperBiiz)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR4-2400 Memory  ($48.98 @ Newegg)
Storage: Seagate Barracuda ES 1TB 3.5" 7200RPM Internal Hard Drive  ($44.99 @ Amazon)
Video Card: EVGA GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($376.99 @ SuperBiiz)
Case: DIYPC MA08-BK MicroATX Mini Tower Case  ($24.99 @ Newegg)
Power Supply: SeaSonic ECO 430W 80+ Bronze Certified ATX Power Supply
Keyboard: Razer Deathstalker Expert Wired Gaming Keyboard
Total: $731.83
Generated by PCPartPicker 2017-01-23 13:30 EST-0500
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/727501-need-pc-help-quick/#findComment-9250674
check 7500 as the cpu are a little cheaper and better then skylake
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/727501-need-pc-help-quick/#findComment-9250762
Maybe see if you can find a used CPU off ebay or CEX?
https://us.webuy.com/product.php?sku=SCPUINTI56500KA#.WIZUmly8otE
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/727501-need-pc-help-quick/#findComment-9250796
