1 minute ago, NoobiexD said:
in that case wouldn't it be best to get the 6700k then?
its really up to you depends what you do, if you watch Netflix the 7700k has an advantage. in most things its impossible to tell the difference between the 6700k and the 7700k. if you have a aio like h100 or a x61 you can get the 7700k to 5ghz.
https://linustechtips.com/topic/727234-i7-7700k-cpu-cooler/#findComment-9247744
no because the 7700K has more performance.
basically the 7700K is a factory overclocked 6700K (plus some other enhancements, but those are minor) because of this, the 7700K is very good at overclocking, and is overclocked (compared to the 6700K) out of the box.
because of this, it does run a little hotter
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/727234-i7-7700k-cpu-cooler/#findComment-9247748
