hi im going to building my own pc and i wanna know if i wanna change somthing or not.
 my budget is aroud $1300 to $1400 and im in canada
this system will be for gaming a bit of editing and maybe some virtual machines and i probally would want to make it futreproof. i will also be doing overclocking
I also might want to get a korean 27inch 1440p monitor or 1080p  asus monitor and i will have another monitor that i already have use it as secondary for other stuff. will also run  on win7 and what are your recomendations for gaming mice and keyboards.
mice, keyboard, speakers, monitor and win 7 not included in budget
MSI z77a-g45 gaming
i5 3570k
or
msi z87a-g45 gaming
i5 4670k
corsair h100i
rosewill hive 750w
kingston hyperx 120gb ssd
segate barracuda 2tb
sapphire hd 7970
or a 280x
fractal r4 w/window
2x gskill ripjaws x 2x4gb sticks 1600
Thanks
https://linustechtips.com/topic/72705-build-help-and-decisinos/
Are you going to over clock at all?
Because for $1400 i'm thinking you could do a lot better.
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/72705-build-help-and-decisinos/#findComment-995793
go 4670k route, its cheaper and better
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/72705-build-help-and-decisinos/#findComment-995811
Not necessarily. Overclocking wise, no it's worse. HD graphics wise it's better.
The Graphics are the only thing that are better in the 4670K over the 3570K. Well that and energy efficiency.
https://linustechtips.com/topic/72705-build-help-and-decisinos/#findComment-995817
Go with a r9 280x its the same as a 7970 but cheaper
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814202046
My rig : CPU: Intel i7 4820K   Motherboard: Gigabyte GA-X79S-UP5-WIFI   RAM : Kingston hyper X 2133MHz 2x 8GB total 16GB   CPU-Cooling : Corsair H60 V2   SSD : Intel 335 series 180GB   PSU : Corsair RM series 750w   Chassi : Corsair Graphite 600T   GPU : Asus radeon HD7750 ( gonna upgrade soon )
https://linustechtips.com/topic/72705-build-help-and-decisinos/#findComment-995820
overclocking wise a 4.3ghz 4670k is better than 4.5ghz 3570k
https://linustechtips.com/topic/72705-build-help-and-decisinos/#findComment-995825
Proof? They're both Quad Cores. One will produce more heat. Even when it's clocked 200Mhz lower.
https://linustechtips.com/topic/72705-build-help-and-decisinos/#findComment-995833
Mattmn: Where will you be shopping for these parts?
https://linustechtips.com/topic/72705-build-help-and-decisinos/#findComment-995858
clock for clock the 4670k is better than the 3570k, i wasnt accounting for heat
and z87 is a better chipset, if they do perform the same then by the chipset the z87 is better
https://linustechtips.com/topic/72705-build-help-and-decisinos/#findComment-995878
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: AMD FX-8320 3.5GHz 8-Core Processor ($166.15 @ Vuugo)
CPU Cooler: Be Quiet DARK ROCK PRO 2 67.8 CFM Fluid Dynamic Bearing CPU Cooler ($69.99 @ NCIX)
Motherboard: MSI 990FXA-GD65V2 ATX AM3+ Motherboard ($139.99 @ Canada Computers)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($84.99 @ Memory Express)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Disk ($187.25 @ Vuugo)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($64.50 @ Vuugo)
Case: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case ($89.99 @ NCIX)
Power Supply: SeaSonic M12II 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($119.99 @ Newegg Canada)
Other: Non reference 290 ($450.00)
Total: $1372.85
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-11-05 13:57 EST-0500)
https://linustechtips.com/topic/72705-build-help-and-decisinos/#findComment-995952
Imo best balanced system:
http://ca.pcpartpicker.com/p/1XQV4
The cooler on the GFX card is beast , this results in titan like performance ( if overclocked of course ) and definitally beats the 290X ( with the stock cooler this is )
Also this build is extremely silent, all the parts are silence optimized.
Interested in Business and Technology
https://linustechtips.com/topic/72705-build-help-and-decisinos/#findComment-996128
My recommendations: http://ca.pcpartpicker.com/p/1XVy5
What you choose for sound will really depend on how much money you want to sink into it--you might want to head over to the audio section for that.
https://linustechtips.com/topic/72705-build-help-and-decisinos/#findComment-997020
should i get a gtx 770 or a hd 7970??
7970. Better value, 3GB vram. But if you can wait for the aftermarket R9-290's then please do that. They will kick some ass.
NZXT Phantom windowed, Asus Z77 Sabertooth, Intel 2600K, Noctua NH-D14, EVGA 780 Classified, Crucial Ballistic Tactical, Crucial M4 128GB + Samsung 850 EVO, Corsair RM850, Creative X-Fi Fatal1ty Peripherals: Sennheiser HD598, FinalMouse Classic, SteelSeries Qck Heavy, Ducky Shine Zero (MX Brown), AOC G2460PF & Qnix QX2710
Build Log: Phantom - Antique Noctua
https://linustechtips.com/topic/72705-build-help-and-decisinos/#findComment-1027642
