I have bought a dj controller and its uses its own audio output but in my system I use a external soundcard (scarlett 2i2) for my two speakers! When I go to use the dj controller it can only work with its own audio output because i need to use the headphone mix on the decks to mix tracks in! All i need to do is route outputs 1 and 2 from the decks into my soundcard but still keep the output 3 and 4 on the decks for the headphone mix! I could just plug the speakers into my computer but I dont have the right cables for it because it needs to go into a single 3.5mm jack and i have 2 1/4 jack plugs going into the back of my soundcard on for left and right.
Windows 10
hercules Dj air controller
Scarlett 2i2 soundcard
https://linustechtips.com/topic/726940-dj-controller-and-external-soundcard/
So what's your issue, it seems you already know what you need to do. Using the direct monitoring option might allow you to not to need to use a daw to get the outputs from the 2i2.
An alternative would be to just connect the speakers to the controller directly.
