I've always want to build my own computer ever since I've started gaming at about the age of 15. I started gaming on a basic home computer and from there on to a decent laptop, and for the most part the games where playable. Around 2014 or so I bought a built computer of a college student for about 600 $USD (California), this is the current computer I have and use. I use it mainly for streaming movies, shows and playing video games like Overwatch, some steam games. I just got a new job that pays better then before and now feel is the time to start anew. I plan on being able to play VR games and really just play the games i like at their max. I've never built a computer before and have minimal experience, a lot of Linus' videos help answer a lot of questions i had like about what i might need/want. My main concern before I buy all the parts are, are they all compatible and will I be bottle-necking any of this parts. I've looked over these questions myself and would just like some experienced eyes to look these over and warn me of any possible troubles. I've attached a .pdf listing ideally everything in want/think i need. Please I want to hear your opinions and advice.
        Thanks Fourm Yours Truly,
        KrypticGeass
Current Computer specs-
Motherboard- gigabyte ga-990fxa-ud3
CPU- AMD FX 8320 8 core 3.5 Ghz
Graphics- AMD Radeon HD 7800
Ram- 8Gb
Monitor- Samsung 55" 4k TV
Keyboard- Logitech K250 wireless
Mouse- M705 wireless
Bluetooth- Intel Dual bandwireless AC 7260
My First Build.pdf
https://linustechtips.com/topic/726749-first-build/
        KrypticGeass
Ram- 8Gb
My First Build.pdf
Seems good, just like @deXxterlab97 said, might want to reconsider the GTX 970 for at least a 1070 if you plan on VR.
https://linustechtips.com/topic/726749-first-build/#findComment-9242496
Too much money spent on that RAM (can find 16GB for $80)
If you choose an AIO, do it for aesthetics, they're not very quiet.
I would put a 1070 on that computer. The 970 has the performance of a $200 card as of today. Yes you can make budget room for it.
I like your case and PSU choices.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/726749-first-build/#findComment-9242497
2
whats with people buying expensive ram i know some uses but still.
https://linustechtips.com/topic/726749-first-build/#findComment-9242503
Not sure. But we're here to correct that.
On an unrelated note, I have fallen in love with this keyboard.
Computer Specs:
https://linustechtips.com/topic/726749-first-build/#findComment-9242508
Just now, Miguel552 said:
Which keyboard?
It's less about the keyboard itself and more about the mechanical switches. (Rosewill Apollo RK-9100 with Cherry Red).
Computer Specs:
https://linustechtips.com/topic/726749-first-build/#findComment-9242516
You saying AiO are not worth it? I thought they were better than high end air when it came to noise and cooling?
https://linustechtips.com/topic/726749-first-build/#findComment-9242520
2 minutes ago, nerdslayer1 said:
64gb ram paired with a 8320.... really don't know what to say.
That would be 64GB RAM with a 7700K. Still a bit silly but less so. You can comfortably edit 4K video on 32GB and a 7700K.
Computer Specs:
https://linustechtips.com/topic/726749-first-build/#findComment-9242533
Let's not derail the thread now xD
Wait for OP's response.
Computer Specs:
https://linustechtips.com/topic/726749-first-build/#findComment-9242537
1 minute ago, KrypticGeass said:
Lol you guys are responding fast then i can look for new parts. I'll re-post new list in a few minutes.
Try and use www.partpicker.com it will also help you with compatibility, and use the embedded to post your list here for easy viewing for us.
https://linustechtips.com/topic/726749-first-build/#findComment-9242562
Should end up something like this.
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($344.75 @ OutletPC)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($102.99 @ B&H)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($144.99 @ Amazon)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($109.89 @ OutletPC)
Storage: PNY CS1311 480GB 2.5" Solid State Drive  ($130.07 @ B&H)
Video Card: Asus GeForce GTX 1070 8GB Video Card  ($418.99 @ SuperBiiz)
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case  ($90.98 @ Newegg)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($78.89 @ OutletPC)
Total: $1421.55
Generated by PCPartPicker 2017-01-22 00:30 EST-0500
Edit: sorry, that motherboard should have been the z270 version, not z170.
https://linustechtips.com/topic/726749-first-build/#findComment-9242593
Thanks for showing me that partspicker i used you r list and just made some changes
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.88 @ OutletPC)
Motherboard: Asus PRIME Z270-A ATX LGA1151 Motherboard  ($166.99 @ SuperBiiz)
Storage: Sandisk X400 512GB M.2-2280 Solid State Drive  ($147.99 @ Newegg)
Operating System: Microsoft Windows 10 Pro OEM 64-bit  ($129.77 @ OutletPC)
Total: $1523.13
Generated by PCPartPicker 2017-01-22 01:01 EST-0500
https://linustechtips.com/topic/726749-first-build/#findComment-9242656
