6 minutes ago, OsuMasterz said:
erm, where's the cooler?
do you mean what?
2 minutes ago, maxilradstudio said:
what do you mean? its on the cpu
quote people
what mobo do you have
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
You should have said Celcius, I got a little confused there. I recommend you swap out that thing because it's running FSB speeds which is a little old. If you can't tell us your motherboard.
He didn't read the part saying Fahrenheit :P
USEFUL LINKS:
PSU Tier List F@H stats
yeah i dont really know, it says the max CMOS ratio is 11 so...
quote people. what motherboard, boot into an os and get hardware monitor
Go into the bios and see if it's listed there, but it's probably not going to since its from the manufacture and they don't expect you to OC it.
9 minutes ago, maxilradstudio said:
well i just wanted to see what could happen
I believe that chipset supports overclocking but honestly it's so old there's not much of a point. It's not going to be stable most likely and the benefits aren't worth the time. Before you do any overclocking you should stress test it, if your temps get too high there's going to be limited overclocking you can do. If it's stable for a while then I guess you could go into the BIOS and up the multiplier and vcore a bit but don't expect to go far. The Q6600 was a decent CPU and still manages to run moderately with some overclocks, I'd grab one of those for $20 off ebay if you want to see any actual change.
  • 2 months later...
