Simply install the card into an empty PCI-e slot and install necessary drivers for the version of Windows you're using.
Someone else could probably find a better one for you than I could, but...
https://www.amazon.com/TP-Link-Wireless-Express-Adapter-TL-WDN4800/dp/B007GMPZ0A/ref=sr_1_3?s=pc&ie=UTF8&qid=1485026950&sr=1-3&keywords=WiFi+card
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/726522-wifi-card/#findComment-9240280
20 minutes ago, JackyPhilibooty said:
I couldn't find which motherboard this comes with but you are likely to need either a PCI-e 1x or a PCI wireless card, do not buy USB wi-fi sticks they do work  but are very likely to give you bad performance and headaches.
Installing them is easy, it is the very same work you'd have to install a GPU, if you have no experience with it though there are plenty of videos across youtube teaching how.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/726522-wifi-card/#findComment-9240285
im not very good with specs on them though, could you please link a few
https://linustechtips.com/topic/726522-wifi-card/#findComment-9240302
Any TP-LINK Wireless Card of 150mbps or higher will suffice if you just need a home internet connection that works solid enough, search on your favourite webstores for the best deals.
It is rather more important, if you already have the PC with you, open its case and send us a picture of its inside to be sure which port is the best one for you to use between those 2 I listed.
Personal Desktop":
https://linustechtips.com/topic/726522-wifi-card/#findComment-9240321
