@Majestic But anyway i have to change this ram because is deffective right?
 And can you tell me, if the ram is broken, what do I have to say to the shop where i bought it? Because they asked me what's the problem and I want to be the more precise I can! Thank you!
Yes, it seems the ram is defective.
Tell them it failed memtest and causes crashes. Any computer shop will know what that means.
35 minutes ago, corrado33 said:
You may even want to bring in pictures of your screen shot from above.
I'd say it's imperative that he does.
That said, failing RAM can be the cause of a faulty Mobo, bent pins or unstable IMC in the CPU. But the ram is the easiest to swap out :)
@dariotrincas Just send them the link to this thread.
Test #7 does block moves that are higher bandwidth than any of the other tests. So memory that can't keep up with the full speed of the MB/CPU will often see errors that do not show up with other tests.
I don't know, I think it's odd that it failed in the same place twice.
Better yet, that it didn't fail any of the prior tests consistently.
So it's not like it'd be a bad module, right? At least not in the sense that it can't retain information, so it isn't OUTRIGHT busted.
I'd try bumping up CPU NB voltage a little. From what little I'm reading here, it's normal for these chips to run in the 1.2v range at stock voltage. So, maybe the motherboard is just being a bit stingy which is resulting in a single core failure when put under stress. This would probably render a more consistent result than an unstable clock, as it wouldn't fail until put under sufficient load.
  • 4 weeks later...
@Majestic@corrado33
Hi everybody. So I finally got the money to buy a new ddr4 stick. It passed the memtest without any error :)
Really happy about it. Also the stress tests are now going well.
Again, thank you for your support! It really helped me out.
Greetings from italy.
3 minutes ago, dariotrincas said:
@Majestic@corrado33
Thanks for the feedback, glad we could help.
