Hi Everyone,
I was thinking about linus' recent unboxing of the PA279Q (link below) and I was thinking about how someone who is primarily a gamer, such as myself, would utilize such a beautiful piece of equipment.
http://linustechtips.com/main/topic/71126-asus-pa279q-where-to-buy/
The only reasonable way would be to buy a work station card or two. I dont really want to buy a quadro K4000 because that is a very old architecture and I would rather get something a little bit more recent.  My thoughts led me to the Fire Pro V7900. A reasonably priced Workstation card that is build for accurate colour.
http://www.amd.com/us/products/workstation/graphics/ati-firepro-3d/v7900/Pages/v7900.aspx#1
Would this preform at all decently in games such as The Elder Scrolls 5 Skyrim, Metro Last Light, The Witcher 2, Mass Effect, ect. I would not be playing multiplayer, fast paced games, just ones that are purely game world experience oriented.
I know this is a big investment for not huge performance in terms of gaming returns, but would it be worth it? I personally think it would improve a single player and RPG experience. It would also be useful in future if I needed to edit and render video or 3D animations ect.
Maybe Cross fire to improve performance when I have enough budget?
What are your thoughts?
EDIT: Just to be clear this is about overall experience and colour, not performance.
  i5 4440, 8GB 1600 mhz, Gigabyte Z87X-UD3H, SX900 128gb SSD, 850w 80+ Gold, FD R4, 270
https://linustechtips.com/topic/72546-fire-pro-v7900-for-gaming/
Most workstation GPUs aren't given the same driver support as gaming GPUs (not worse, just a different focus). So there is alot of wasted performance while gaming, most people recommend against it.
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
https://linustechtips.com/topic/72546-fire-pro-v7900-for-gaming/#findComment-993610
If this is for primarily gaming, definitely get a gaming GPU.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/72546-fire-pro-v7900-for-gaming/#findComment-993611
Its about colour, not gaming performance.
Colour has absolutely no basis on your graphics card.
https://linustechtips.com/topic/72546-fire-pro-v7900-for-gaming/#findComment-993629
Yeah I can see that. Who knows though.. someone should reach out to GPU devs to get them to make better gaming drivers. although that will never happen.
https://linustechtips.com/topic/72546-fire-pro-v7900-for-gaming/#findComment-993630
what do you mean?
Unless you change settings at the driver level, the same image file from a 780Ti is the exact same as a K6000, which is the exact same as a V7900.
https://linustechtips.com/topic/72546-fire-pro-v7900-for-gaming/#findComment-993638
At 10 bit color, a game will look unrealistically oversaturated.
Stay with a gaming card.
https://linustechtips.com/topic/72546-fire-pro-v7900-for-gaming/#findComment-993639
You can see more benchmark here how workstation perform in gaming.Although it does not have v7900,but you could compare it to the other card here.
http://www.tomshardware.com/reviews/workstation-graphics-card-gaming,3425-2.html
https://linustechtips.com/topic/72546-fire-pro-v7900-for-gaming/#findComment-993648
it acutally is there. in the middle.
https://linustechtips.com/topic/72546-fire-pro-v7900-for-gaming/#findComment-995002
so a poorer performing 780 is the result?
https://linustechtips.com/topic/72546-fire-pro-v7900-for-gaming/#findComment-995005
But doesnt the GPU designate the colour output to the monitor. which then, can or cannot, display that colour.
https://linustechtips.com/topic/72546-fire-pro-v7900-for-gaming/#findComment-995078
