Hi Guys!
My dad has asked for what I want for my 18th birthday. I was thinking for asking him for a water cooler, which one should I get? We live in the UK (Not really any set budget I suppose? I have a phanteks enthoo pro m acrylic
I have a be quiet dark rock 3
I want a cooler that looks nice, fits in my case and is near damn silent, I hate noise in my pc with a passion
https://linustechtips.com/topic/725448-water-cooler/
air coolers are quieter most of the time, especially when you are pushing your system to the limit. water coolers do look nicer, but at the cost of more noice.
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
https://linustechtips.com/topic/725448-water-cooler/#findComment-9228598
Buy big and set your fan curves so that the fans run at lowest speed all the time.
I have my H115i set to throttle up from 30% to 100% at 75* over a period of 125 seconds. It's quiet (quiet enough for me to sleep at night), and I'll bet if i throw some SilentWings3 PWM fans on there, it'll be even quieter. but at speeds above 1200RPM with the stock corsair fans it's VERY loud.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/725448-water-cooler/#findComment-9228602
4 minutes ago, GeorgeKellow said:
Is it near silent?
Yes new serioes from NZXT should be very silent.
But I'm not sure if you will get any lower temperatures with AIO. be quiet dark rock 3 is a decent cooler.
May I ask what are your temps now? What CPU are you using? Any OC? voltage?
Or you want AIO just because it looks cool? That was acctually my reason for buying first AIO so I can relate to that xD
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/725448-water-cooler/#findComment-9228607
