I forgot where I heard it but what is base clocking. I have a z170 motherboard and an i5-6600. What does it do and could it help me.
A smile goes much farther than the person it's meant for.
First impressions are important, it sets the stage for respect.
"If you don't know every word you don't know it!"- SGM McCray
https://linustechtips.com/topic/725237-what-is-base-clocking/
BCLK, or base clock, is half of what determines the frequency of your CPU and RAM. They each have that base clock and a multiplier. The multiplier times the BCLK determines the speed they run at. Since you have a CPU whose multiplier cannot be changed, some people change the BCLK to overclock their CPU. This used to be a bigger problem when it was used for more things, but on skylake you can manipulate it without really harming other components.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/725237-what-is-base-clocking/#findComment-9226309
How would you go about changing your BCLK?
https://linustechtips.com/topic/725237-what-is-base-clocking/#findComment-9226318
In your BIOS, there should be an area for "tweaking", "tuning", overclocking, or something similar. Here you should find this setting fairly easily. it is usually called BCLK, or sometimes the strap.
Here is an example of someone doing this:
https://linustechtips.com/topic/725237-what-is-base-clocking/#findComment-9226323
Thank you! This helps so much.
https://linustechtips.com/topic/725237-what-is-base-clocking/#findComment-9226330
My pleasure
https://linustechtips.com/topic/725237-what-is-base-clocking/#findComment-9226337
