Hi, I want to build a PC soon and I have a budget of $500. I live in the US. I wane to use this PC for gaming (CS:GO) and record it and upload it to YouTUBE. I currently am receiving a nice motherboard (I'll add a picture), CPU Cooler(Zalman and don't know what kind), i5-3750k, 420-watt power supply, and DDR3 4x4gb of ram. So I currently need the following: GPU, Monitor, Keyboard, wifi USB, SATA Storage,and case at the minimum budget, and I guess I'll need windows 10 too.
The things I am receiving are from a nice friend that has a new PC so yay!
IMG_0530.jpg<---Mother Board with some Zalman cooler thing.
I guess I'll add a pcpartpicker of the things I need to get: https://pcpartpicker.com/user/Whalzie/saved/7CBTWZ
Best,
Zusher
https://linustechtips.com/topic/725197-first-build/
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor
Motherboard: Gigabyte GA-Z77X-UD5H-WB ATX LGA1155 Motherboard
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.66 @ OutletPC)
Video Card: PNY GeForce GTX 1060 6GB 6GB Video Card  ($246.39 @ SuperBiiz)
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter  ($9.89 @ OutletPC)
Monitor: AOC i2267Fw 22.0" 1920x1080 60Hz Monitor  ($104.99 @ B&H)
Keyboard: EagleTec KG010 Wired Gaming Keyboard  ($52.67 @ Amazon)
Other: 32 gigs of ddr3 ram (Purchased)
Other: windows os from kinguin ($30.00)
Total: $493.60
Generated by PCPartPicker 2017-01-18 22:02 EST-0500
you could get a cheaper mechanical keyboard and then add in a cooler master cpu cooler and  a case if you wanted to
https://linustechtips.com/topic/725197-first-build/#findComment-9225856
Total: $493.60
damn
Best,
Zusher
https://linustechtips.com/topic/725197-first-build/#findComment-9225868
1 minute ago, Zusher said:
damn
wdym
btw i strongly recommend getting the monitor and keyboard i've linked - the monitor is ips and has a relatively fast response time - and the keyboard may not have cherry switches, but the blues on it are actually really good for gaming - only thing i could see that you could compromise on is the gpu - a 1050ti 4gb will run games like battlefield and overwatch at 70 fps on high - and with the saved money you could either get a really cheap corsair cx450m psu when it's on sale with the mail in rebate for 20 dollars and get a nice case
https://linustechtips.com/topic/725197-first-build/#findComment-9225881
Total: $493.60
I guess you should drop the keyboard to a much cheaper price xD
and I just might be able to get a monitor from my grandparent xD
Best,
Zusher
https://linustechtips.com/topic/725197-first-build/#findComment-9225882
get a new monitor, i have a feeling a monitor from grammy isn't gonna cut it for gaming
https://linustechtips.com/topic/725197-first-build/#findComment-9225884
also, the keyboard should be kept as is, mechanical is needed for gaming, a gaming mouse can be bought on gearbest.com or amazon for a pretty cheap price
https://linustechtips.com/topic/725197-first-build/#findComment-9225892
