(English is my third language dont juge me)
I've made my first not expensive gaming computer:
https://fr.pcpartpicker.com/user/afospinat/saved/#view=WRDJxr
I've based my configuration in different videos in the linus channel of youtube, other people configurations in pcpartpicker and somme other references in the internet.
I've made some mistakes in my configuration???
And the other thing is that i dont have a monitor, I thought use my TV (Samsumg UE32H6410 with hdmi 2.0), but as i research it is not the best option... any thoughts that could help me?
(Remember im in a budget)
Thancks
https://linustechtips.com/topic/724459-help-first-build-already-chose/
Thancks
Get ddr4 not ddr3 ram, for $210, get a rx 470 or a 480 (8 gb if possible), otherwise good choices
This isn't a good build. Give me a few minutes; I'll come up with a better build and fit in a monitor too.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
Thancks
what's your budget?
8 minutes ago, afospinat said:
Ok thank you
7 minutes ago, afospinat said:
600 euros
Thanks
Includes a hyperthreaded Pentium that is about equal to a Core i3 6100, an RX 460, and a 1080p monitor. Also, cheaper Windows (link in parts list)
CPU: Intel Pentium G4600 3.6GHz Dual-Core Processor  (€96.90 @ Amazon France)
Motherboard: MSI H110M PRO-D Micro ATX LGA1151 Motherboard  (€59.26 @ Amazon France)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  (€59.90 @ Amazon France)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€52.90 @ Amazon France)
Video Card: Gigabyte Radeon RX 460 2GB WINDFORCE OC Video Card  (€114.90 @ Amazon France)
Case: BitFenix Nova ATX Mid Tower Case  (€36.98 @ Amazon France)
Power Supply: be quiet! Pure Power 9 400W 80+ Silver Certified ATX Power Supply  (€54.90 @ Amazon France)
Monitor: Hannspree HE225DPB 21.5" 1920x1080 Monitor  (€107.95 @ Amazon France)
Other: Windows 10 OEM Key (Kinguin) (€24.00)
Total: €607.69
Generated by PCPartPicker 2017-01-17 19:21 CET+0100
Well first of all, a TV is not bad at all for gaming, yes it's refresh rates are not that accurate and there is gonna be a lot of frame filling involved but i personally gamed on a 49" 1080p TV for a year and half when i first build my PC and if anything i miss it. Since you have a display solution and it's not one with Nicki Minaj's ass, not that old, don't waste money on a new monitor. spend the chunk of your money on the tower than think about getting a "proper" solution.
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
3 minutes ago, afospinat said:
Yeah but the next with good value it is like the i5-6500, and it is too expensive
You'd be better saving a little more money until you can afford the 6500, or even a i5 6400. It'll be miles better and worth the extra.
2 minutes ago, Aereldor said:
Includes a hyperthreaded Pentium that is about equal to a Core i3 6100, a GTX 1050, and a 1080p monitor. Also, cheaper Windows (link in parts list)
Video Card: Inno3D GeForce GTX 1050 2GB Compact Video Card  (€125.28 @ Amazon France)
Total: €618.07
Generated by PCPartPicker 2017-01-17 19:16 CET+0100
5 minutes ago, afospinat said:
600 euros
Thanks
That's probably the best you can do on your budget.
With retail parts, yes.
Total: €618.07
You call this a better build ?! you downgraded him from a 1060 to a 1050, and for what, a Pentium, even the outdated 860K with it's higher clock speed and more cores will do better.
I dont know to much, but the amd is a quad-core, vs the Intel is dual core, that's why i didnt chosse that one, but still if you say me that is better that way i will continue my reseach
intels single core performance has been better than amds for quite some time now, hence why even though the amd cpu has more cores its technically worse than the intel cpu
The cpu is less powefull (http://www.cpu-world.com/Compare/33/AMD_Athlon_X4_860K_vs_Intel_Pentium_Dual-Core_G4600.html), but I will take your advice for the reasons:
1- this configuration could be upgraded easily (same socket as the i5 6500)
2- DDR4 (is the same price and for the others applications as work is better)
3- i think you know most than me (i started before yesterday)
But still i will play in my tv, and dont change my graphic card. What do you think?
Thanks
Thanks
True.
Yeah just stick with your TV. Try and squeeze a 6GB 1060 in there and get a proper monitor later.
Thanks
neither the Pentium nor the 860k support ddr4 and the pentium is better as shown here http://www.techspot.com/review/1017-best-budget-gaming-cpu/page2.html
Thank you!! i almost make that mistake!!, so im screw....
