alright here is my problem currently i have my i5 4690k at 4.6ghz and 1.25v i have ran aida64 and cpuz multi threaded stress test and my computer isnt crashing but it was when i had the voltages down at 1.225v but sense it was stable i started to do the Aida64 GPGPU benchmark i had unchecked the integrated graphics and it started running then after the AES 256 test blue screen and my pc restarts is there a Fix Should i Up the Voltages or what please help!! also what was very odd right before it crashed the Debug LED spiked up to 90 which cold have been CPU temp i do not know.
My computer was originaly crashing at 1.225v @4.6 on CPUZ stress test.
First PC Build
CPU: i5 4690k  (4.7Ghz 1.36v)                                        MOBO: MSI z97 gaming 5
GPU: MSI GTX 1070 gaming x                  Case: NZXT s340 elite Black/Red
Storage: 1tb seagate SSHD, 240gb PNY ssd                    PSU: Corsair RM750X
Cooling:H100i V2 / Bequiet Fans
16GB Hyper X Fury Memory
Benched on CPUZ (Single-thread=2140) (Multi-Thread=8316)
Fire Strike 1.1=13660
Time Spy=5519
Cinebench R15 (CPU= 509cb) (OpenGL=118.28 FPS)
Unigine (Superposition 4k optimized=5581) (Heaven Extreme=120.6 FPS Score:3038) (Valley Extreme HD= 92.7 FPS Score:3879)
https://linustechtips.com/topic/724047-important-need-over-clocking-help/
more voltage, im running 4.7GHz at 1.335V on my I5 4690K. you will want to do a 24h AIDA64 validation run too aswell when you find something stabile
Builds:
just run aida 64 stress test for 24 hr?
you think 1.28 or 1.3v should be good
First PC Build
Time Spy=5519
yah just up the voltage, do a 10min run to make sure its atleast somewhat OK then if it passes that do a 24h run, if it can take 24h of AIDA64 its good
Builds:
how do i now if the voltage is too high will it just get hotter
First PC Build
Time Spy=5519
there is no too high before you reach 1.4V really, but if also keep an eye on temps. if your CPU reaches more then 85C you will want to turn down the voltage and with that probably also the multiplier
Builds:
3 minutes ago, Captain Chaos said:
What temps are you getting?
Also, why is it that I hear "brrrrt" in my head whenever I see your avatar fly by?
upper 50's 58 maybe NOW 62 63
First PC Build
Time Spy=5519
currently testing CPU FPU and Cache
First PC Build
Time Spy=5519
First PC Build
Time Spy=5519
