so I was helping this guy setup a pc and it cam to this page where it said that we needed to reset the time because cmos was reset. SO when we reboot the pc and click enter bios it just automnatically takes us to the cmos page whenever we click something. PLEASE help because it was kinda my fault and I really need to fix this.
THANKS.
Edited by W-L
Title
https://linustechtips.com/topic/723664-bios-help/
what do you mean CMOS page? what does it prompt you to do? enter the time?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/723664-bios-help/#findComment-9208219
it says copyright stuff then bios update then time then CMOS dat/time not set: press F2 or DEL to run setup or F1 to continue. WHen we click those nothing happens
https://linustechtips.com/topic/723664-bios-help/#findComment-9208228
