Replacement remote for Amazon Fire Stick
Solved by johnt,
Your efforts are futile. You aren't going to find anything cheap as the TV Stick uses Bluetooth, which is a trigger word for the market to charge more. Plus, the Stick is grade A, premium Chinese design... which means the entire package isn't worth "repairing." Your best alternative is to buy another TV Stick from Amazon that comes with a remote. And advise your mother in law to stop going ham on plastic things from China.
