2 minutes ago, KappaGod said:
I just got a 960 evo 1tb, it reachers 60+ during stress tests.
I know this is normal and its "fine" but i want it to be better than fine
Any solutions? thinking something like piece of aluminum with thermal pads.
That could work i guess. or just put in behind a fan. get something small like....for example a raspberry pi heatsink, but a little larger so i could cover the surface
https://linustechtips.com/topic/722684-m2-cooling/#findComment-9198456
Thats not a bad idea, or you could buy mini heatsinks (like 10 bucks for 20 of them depending on the store), and then use thermal adhesive to stick them on the chips that are heating up. If you can't or dont want to do that for some reason, you could always position a fan to blow on it, make sure that the airflow path in your case is blowing across it.
https://linustechtips.com/topic/722684-m2-cooling/#findComment-9198467
