I have a pair of ad700xs which ive had for a bit less than a year and recently the jack started actingg weird. If i plug it in normally it sometimes plays sound only out of one ear as if the jack is loose. I have to push it in and wiggle it around for a bit to get it to play sound out of both ears. I usually alternate between my tv, ipad and pc. So i plug and unplug them a lot. Does anyone know what might be happening and if theres a way to fix it? Thanks in advance.
https://linustechtips.com/topic/722601-headphone-jack-issue/
Try replacing the jack.
I don't see why you wouldn't just bump the thread you posted the other day that has the *exact same* question.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
https://linustechtips.com/topic/722601-headphone-jack-issue/#findComment-9197560
I couldve but i figured maybe the title was making people skip over the article. Anyway how can you replace the jack?
https://linustechtips.com/topic/722601-headphone-jack-issue/#findComment-9197607
You cut off the old one, get a new one, and solder it on.
Hey! New SIgnature!
https://linustechtips.com/topic/722601-headphone-jack-issue/#findComment-9197626
Unfortunately, they don't have a removable cable, so what he said:
If you're not very confident in your ability to do this then ask someone you trust.
But before you jump the gun, just check the headphones with a different device, and a different pair of headphones with the original devices.
https://linustechtips.com/topic/722601-headphone-jack-issue/#findComment-9197739
This is a very good expansion on what I was saying. Thanks!
Hey! New SIgnature!
https://linustechtips.com/topic/722601-headphone-jack-issue/#findComment-9197750
