I delidded a 6700k in November, which had very different core temps before that. I applied Noctua compound in place of the stuff Intel had, put it back together and temps were improved. All was well. Tonight I was switching from a lower stress compute application to a higher one, and it rebooted. On checking temps, I saw 24C difference between coolest and hottest cores. The old problem had come back. Took it apart again, and the compound pattern seemed ok. Any ideas? I'm thinking if a thicker one might hold better?
I should add, I'm only looking at ordinary non-conductive compounds. I'm not considering liquid metal ones.
https://linustechtips.com/topic/722564-post-delid-compound-choice/
Kryonaut. Getting the best TIM is important for delids.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
When you say the compound pattern seemed ok, do you mean that the whole, and I mean the whole, die is covered in thermalpaste or that it is kinda spread over it. If not every mm2 of the die is covered in thermalpaste you are asking for problems.
If I were you I would actually consider the coollaboratory liquid ultra. I know you said that you aren't considering them, but it has quite a bit of difference vs thermalpaste like arctic mx-4. I tried both on my old 3770k@4.9GHz and I noticed a 5(!!!)°C difference just by getting a different thermalpaste and the spread on the arctic mx-4 was good. You could ofcourse go for stuff like kryonaut as suggested above or the classics like arctic mx-4 (which worked perfectly druing the time I used it, it just couldn't compete with a specialty product and I really wanted the best) or arctic silver 5 (don't have experience with this one though).
Someone once said: "Having a rollercoaster on a PC would be epic"
So threw a rollercoaster on my K'nex PC: Project Dragon Khan- K'nex rollercoaster PC build
Yes, the entire die was covered. I usually apply to excess and it could be seen where the excess had gone.
I went with the Noctua compound as one I had around already, and in comparisons it might not be the highest performer but it was in the upper ranks.
Also I should add, I'm not a hard core overclocker. With this particular sample I had excessive core variation leading to instability I don't see with my other two running at same speed and voltage. The first delid did resolve that, but it seems long term stability wasn't there as it was only about 2 months ago.
I tend to use ceramic ones.  They are usually thicker and non-conductive.  My temps come in pretty low, too.  Some are priced pretty good, while some can get expensive.  Arctic Silver Ceramique is priced pretty good, but haven't compared temps in a long time to some of the other ones on the market.
If you just want stability I could recomend MX-4 thermalpaste all day every day. You just have to apply it once and just let it sit for years on end (though I only used it for ~6 months). The same goes for the coollaboratory liquid ultra, but if you are just planning on improving stability it is way to expensive. I must say though, that same 3770k is still running with the original layer of coollaboratory thermalpaste in someone else's setpu and it has been running cool (max 85°C on air during summer) at 4.9GHz for about 1.5 year now.
I had a poke through my bits bin and found an old syringe of MX-2... quick look around it is similar if not as high performance as MX-4. Think I'll give that a go as what I have on hand.
MX-2 applied and testing now. The spread has gone down, only 4C different between coolest and hottest core, and it is a different pair.
