Hello guys.  I am having a problem with my PC that it won't connect to my internet via Ethernet.  I am running the latest Intel drivers for my Ethernet.  I am running a MSI H110M Gaming with Intel i219 LAN.  I also get this error when I try to reinstall the drivers.  Anything I can do to fix this?  I am running the latest update of Windows 10 Pro.
The error says
There is an issue with Microsoft Windows 10 that prevents the Intel Advanced Network Services feature from working correctly.  You may install this feature, although you will be unable to create Intel ANS Teams and VLans.  Do you wish to install the feature?
https://linustechtips.com/topic/722532-help-ethernet-not-working/
The service for controlling that might be disabled or something. Research a bit about that and see what the service name is and enable it.
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
Try running the "ipconfig" command in cmd as shown below and see if a default gateway is shown:
After this try pinging the router (default gateway IP). Using "ping *ipaddress*":
Or try navigating to the address in a browser:
If you're able to do this then your ethernet port and cable are definitely working at least and it is likely a driver or protocol problem.
Troubleshooting steps:
- Have you tried disabling the ethernet port adapter and re-enabling?
- Windows is sometimes able to fix the issue by diagnosing the adapters connection. Try this.
