Cable Management
Go to solution Solved by iRileyx,
Shut the pc down through start menu and switch the PSU off on the back.
Shouldn't give you any issues then.
I'm gonna cable manage my computer by unplugging everything and routing everything accordingly, but the last time I did that my pc said that it did not start correctly. When this happened I had to reinstall windows and I lost some stuff so what do I do so that doesn't happen ?
https://linustechtips.com/topic/722448-cable-management/
Press shut down on your PC.
M1 MacBook Air 256/8 | iPhone 13 pro
https://linustechtips.com/topic/722448-cable-management/#findComment-9195896
It really shouldn't do that at all so it might be something other than just unplugging the cables.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/722448-cable-management/#findComment-9195900
