Building first gaming PC
Go to solution Solved by Brooksie359,
Get a z270 or a z170 motherboard of you are going with a k variant cpu. That way you can overclock your cpu because you can't on a b150 motherboard. Also get a higher quality power supply. A seasonic s12ii would do the trick nicely
As I have from little to no experience with PC building I thought I should ask people who have more knowledge about it before messing things up. So here are the parts I plan on buying:
Graphics card: MSI GEFORCE GTX 1080 ARMOR 8G GDDR5X 256BIT
CPU: INTEL CORE I7-7700K KABY LAKE LGA 1151 4.2GHZ 8MB CACHE
Motherboard: ASUS B150M-C DDR4, LGA 1151 MICRO ATX, INTEL B150
RAM: CRUCIAL BALLISTIX 16GB (2X8) 2400MHZ DDR4 UDIMM
Case: THERMALTAKE VIEW 27 RING 12 GREEN, CA-1G7-00M1WN-GR
HD: TOSHIBA 1000GB SATA III 3.5", DT01ACA100 - OEM
Power Supply: EVGA 500B 500W, 80 PLUS 100-B1-0500-KR - BOX
CPU Cooler: WATER COOLER CORSAIR HYDRO SERIES H45
As I mentioned before I don't have much experience with these things so if you have any advice or noticed any incompatiblity with the parts or any missing component I would be grateful to know. Also I would like to know if with the little experience I have I will be able to build it myself or if I should find someone with experience to do it for me. Thank you already, waiting patiently for your responses!
https://linustechtips.com/topic/720781-building-first-gaming-pc/
Looks pretty goof but you need a z170 preferably a z270 motherboard
IM BACK BABY
https://linustechtips.com/topic/720781-building-first-gaming-pc/#findComment-9176514
recommenced psu for a 1080 is 600W
https://linustechtips.com/topic/720781-building-first-gaming-pc/#findComment-9176534
Get a better mobo, especially with those top of the line parts you dont want a b150 chipset... i dont even think that's compatible
qυoтe мe pleaѕe!
Me at the Apple store: "So how fast is this little macbook?"
Apple employee: "Cheetah Fast. Lightning Fast. It's Really, really, fast."
https://linustechtips.com/topic/720781-building-first-gaming-pc/#findComment-9176542
Only thing I would add would be switching HDDs. Out of personal experience, Toshiba's are the only drive that I've ever had fail on me. They're probably just rebranded WD or Seagate drives but I'd still go with one of them.
i7 4930k \ Asus P9X79 LE \ Corsair H100i \ 16 GB DDR3 G.SKILL Ripjaw \ Asus Strix R9 380x 4GB \ Crucial 500 GB Sata III SSD \ Thermaltake TR2 RX 850W \ Corsair Crystal 460 Black \ Razer Naga Molten edition \ Razer Black Widow Ultimate \ Klipsch Promedia 2.1 speakers \ Hyper X Cloud Alpha \
i5 6600k\ Asus Z170-A \ Corsair H100i v2 \ 16 GB DDR4 G.SKILL Ripjaw \ Asus GTX 1060 6GB 4GB \ SanDisk 480 GB Sata III SSD \ Seasonic G Series550W \ DIYPC Skyline 06 black/green \ Razer Naga Epic \ Razer Black Widow Chroma \ Logitech 2.1 Speakers \ Logitech G430 \
https://linustechtips.com/topic/720781-building-first-gaming-pc/#findComment-9176577
No. https://www.nvidia.com/en-us/geforce/products/10series/geforce-gtx-1080/
And you could probably run it off less. NVidia recommended >300 watts for a GTX 750; a card which only consumes a measly 55 watts of power.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/720781-building-first-gaming-pc/#findComment-9176586
PCPartPicker part list: https://pcpartpicker.com/list/zwdrwV
Price breakdown by merchant: https://pcpartpicker.com/list/zwdrwV/by_merchant/
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($349.89 @ Amazon)
CPU Cooler: Corsair H55 57.0 CFM Liquid CPU Cooler  ($59.54 @ OutletPC)
Motherboard: Asus PRIME Z270-AR ATX LGA1151 Motherboard  ($159.95 @ B&H)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR4-2400 Memory  ($103.99 @ Amazon)
Storage: Seagate FireCuda 1TB 3.5" 7200RPM Hybrid Internal Hard Drive  ($78.89 @ OutletPC)
Video Card: MSI GeForce GTX 1080 8GB Video Card  ($588.51 @ Amazon)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Jet)
Other: Thermaltake View 27 Gull-Wing Window ATX Mid-Tower Chassis
Total: $1415.76
Generated by PCPartPicker 2017-01-10 11:06 EST-0500
IM BACK BABY
https://linustechtips.com/topic/720781-building-first-gaming-pc/#findComment-9176591
Total: $1415.76
That PSU has bad voltage regulation at higher temps. Switch it out for a G2.
https://linustechtips.com/topic/720781-building-first-gaming-pc/#findComment-9176600
What's your budget and location? I can make a better build.
https://linustechtips.com/topic/720781-building-first-gaming-pc/#findComment-9176615
In my personal opinion I would get some cable sleeves because such pretty parts deserve good accenting here's a link to look at some https://www.amazon.com/gp/product/B01IA9FEJY/ref=ox_sc_sfl_title_10?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
https://linustechtips.com/topic/720781-building-first-gaming-pc/#findComment-9176623
cablemod is better imo
https://linustechtips.com/topic/720781-building-first-gaming-pc/#findComment-9176626
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.99 @ Newegg Marketplace)
Motherboard: ASRock Z170 Extreme3 ATX LGA1151 Motherboard  ($104.99 @ SuperBiiz)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  ($82.99 @ Jet)
Storage: PNY CS1311 240GB 2.5" Solid State Drive  ($64.99 @ Jet)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.66 @ OutletPC)
Video Card: MSI GeForce GTX 1080 8GB Video Card  ($598.45 @ Amazon)
Case: Thermaltake View 27 ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: Rosewill 550W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($74.99 @ Newegg Marketplace)
Total: $1407.04
Generated by PCPartPicker 2017-01-10 11:15 EST-0500
https://linustechtips.com/topic/720781-building-first-gaming-pc/#findComment-9176646
Total: $1407.04
Why a rosewill though?
IM BACK BABY
https://linustechtips.com/topic/720781-building-first-gaming-pc/#findComment-9176696
