Alienware 15 R3 wrist wrest problem?
Guest lilbman
The wrist rest does not go all the way down and is not flush with the chassis like the rest of it.  Also, it is uneven; the left side does not meet the surface it is on, like the right.  When you push down, you feel it touch the surface.  Yes, I've tested it on like 5 perfectly flat surfaces.
So, the problems are the wrist rest and the chassis thing.
Do I A) clamp it to the bottom of the laptop and see if I can bend it back or B) contact tech support and get them to send someone to my home to fix it?
Any suggestions on why the left side isn't evenly setting down on the surface like the right side and how to fix it?
Push hard
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
it could be the battery. I would suggest you get it looked. contact techs support.
You know what happened to Samsung Note? better be safe than sorry. IF i am correct that is the part that stores it right?
I don't know where the battery is located in the chassis, but I can check.
That is where the battery is located
at the bottom. Advice contact Alienware Dell. That is a VERY dangerous product now. There is a good chance that happened due to the battery.
