Nothing shows up for the error when it crashes, i've installed more ram and have decently high end components.
Heres my specs
Graphics Card - Asus GTX 970 (btw is it bad that it droops down a little bit)
Motherboard - Asus Z97
Ram - Corsair 4gb (2 sticks) 4gb (2 sticks) of somthing
Powersupply - XFX 550 watt
Hard drive - WD Blue 1tb
Processor - i7 4790k
btw the crashes happen when i run lots of programs at once
like streaming or lots of chrome tabs, but sometimes it just crashes for no reason
https://linustechtips.com/topic/720561-computer-crashing-help/
Heres my specs
im thinking ram - try to do an experiment - open task manager then open the exact tabs and apps you had open before the crash - if im right, your ram should come close to 100 percent usage - or, the 2 other sticks of something aren't matching ram and you might only have 4gb instead of 6 or 8 or 12 gb
https://linustechtips.com/topic/720561-computer-crashing-help/#findComment-9174007
10 minutes ago, EminentSun said:
Try updating your graphics driver. If its just a black screen an unrecoverable graphics crash is likely the case.
Also prop up ya damb video card!!
graphics driver updated (: and how should i prop it up i have the screws in
https://linustechtips.com/topic/720561-computer-crashing-help/#findComment-9174010
yea this was the problem before, it said ram in the error, so i fixed that problem, but now it just says no error.
https://linustechtips.com/topic/720561-computer-crashing-help/#findComment-9174039
... describe the error and what happens before as detailed as you can - any louder noises from fans you hear? etc
https://linustechtips.com/topic/720561-computer-crashing-help/#findComment-9174045
so i was playing a game then it just crashes and its a still image with like a repearted noise and the the computer  sounds the same as it was running
https://linustechtips.com/topic/720561-computer-crashing-help/#findComment-9174055
2 minutes ago, LabRat said:
sound driver conflict.
disable or uninstall unused drivers.
give better description of ram. if you just upgraded you must know what you installed.
how could i disable the unused drivers and how do i know its unused
https://linustechtips.com/topic/720561-computer-crashing-help/#findComment-9174081
If you wanted to be sure that the problem has anything to do with the software side of things, then you would have to boot it off something else (like Linux for example), and then see if the problem repeats itself. If it does, then it makes it a hardware problem that you have to diagnose and fix.
What exactly happens when it crashes? Any blue screen? Does input into the monitor stop? Can you run your screen off your motherboard video outputs and see if the same thing happens?
https://linustechtips.com/topic/720561-computer-crashing-help/#findComment-9174164
it freezes into a single frame of whatever im doing then after like a minute it transitions into this
https://linustechtips.com/topic/720561-computer-crashing-help/#findComment-9177538
