SP fans or AF fans for cases?
Rahul3D
Hello Friends
I am planning to build new PC. I am into VFX and 3D animation. I do not want to go for liquid cooling. I might go for RAM over clocking not CPU over clocking.
I am gonna buy.My confusion is it should be SP or AF and what should be minimum RPM to be there?
Corsair 460x case
i7 6800K (Brodwell-E)
3 120mm fans at Front
1 120 mm exhaust fan.
CPU cooler Noctua NH-D15S
Thanks
sorry my bad...i already having GTX 750TI 2GB
Make your 3 front fans high SP and the one rear high AF if possible.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
All fans have some degree of static pressure and airflow. The 460X isn't that restrictive at the front and any sort of balanced fan design would work fine.
Why not just stick with the stock fans?
Also a bit curious about the oc'ing--why oc the ram and not the cpu?
I live in india so getting the perfect case we wish is difficult... So if i get 460x not 460x RGB then i have to keep the fan buying option open.
    I mostly do not overclock and work, but this time i might do a both overclocked :)
Ah, can you link us to where you're shopping? What's your budget?
As i am from "Mumbai" There are different shops i have to hunt for different parts and each shops having different cost.Mostly i look "Laminton Road" in Mumbai which is big computer market.My US dollar budget is around 1500, but in india it end up 1700 or 1800 which is sad as parts are taxed.
Are there any of the shops that you can link us to?
May i know why you want to know the shops name? Just curious about it..
Not the names specifically but links to the stores. It's hard to give a recommendation when we don't know what's available to you.
I buy stuff from this store and this is there website, unfortunarely my half of requirement is not there. This is there website http://www.primeabgb.com/
This is another i found just 2 days back seems to be good one. http://www.theitwares.com/
But as i said its difficult to find stuff at one store... :(
There aren't that many options available but out of the two websites, I'd suggest going with NF-S12B's: http://www.primeabgb.com/online-price-reviews-india/noctua-nf-s12b-redux-1200-pwm-sso-bearing-fan-2/
(Kinda interesting that they use an image of the NF-P14S for all their Redux fan listings)
or NF-A15's: http://www.primeabgb.com/online-price-reviews-india/noctua-nf-a15-pwm-140mm-premium-quiet-quality-fan-with-round-frame-aao-technology/
Ohh ok... what if i go for this one three front and back one
http://www.primeabgb.com/online-price-reviews-india/cooler-master-masterfan-pro-120-air-balance-case-fan/
2 minutes ago, Rahul3D said:
MasterFan Pros are alright but are more expensive and not as good as NF-S12B's.
It is just 2$ more expensive for me with higher RPM.
Why would you need such high rpm? If you care at all about noise, you'd probably never run them above 1000rpm and you'd never need to.
With just a 6800k and a 750 Ti, a single rear exhaust would've already been plenty for cooling.
I do not have AC in my room, in india it usual to get hot. So i need more fans with high rpm so they ciuld intake air from outside. I hope you got it :)
You don't.
