12 minutes ago, HAWS said:
I have two questions, 1. Is my gpu fine or is it sagging to much and do I need to prop it up? 2. My back plate is dusty and I was wondering if I can just wipe it off with a paper towel or if I would need to pull it out and use something else to clean it
Sag is neve really a great thing but Idk how you would properly prop it up. I have a tripple slot car that is probably sagging aswell but idk ...the best and probably ugliest idea I can come up with is a woddens tick you can saw and grind to length easily.
While cleaning I would unplug it and drain all the power by holding power for 6+ seconds. A paper towl is probably fine in terms of static.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
