Affect on productivity with surround (eyefinity)
Go to solution Solved by Mick Naughty,
It should do that but after it gets resized it should snap to the edges of a single monitor again. Going full screen in anything will cause that like YouTube.
Unless surround is that much different then eyefinity.
so I had this question, but figured I'd break it off into another thread. so I have 2 monitors now, and I really like the aspect of just dragging a new window to the 2nd, and switch back and forth, make everything much faster, but when I had just gotten my 2nd, I accidently set up an Eyefinity profile (i knew nothing about setting up a 2nd monitor.) and when I opened up chrome, it stretched it across both monitors, and I knew something was up, so I disabled it, and it works fine now, so I'm thinking about getting 2 more, and scraping a old one, and having a 3 monitor surround setup, but will it try to stretch windows? or will it act like 3 monitors, not 1 giant one? thanks all!
10 minutes ago, wrathoftheturkey said:
Don't turn on Eyefinity and you're fine? Or just enable it for games, that's easier.
welp, guess that works, do you know if some games support it with Eyefinity? I think bf4 has like a number of monitors option.
Thanks! again actually, you helped me on the other surround thread I made about a 1070 xD
