Maybe you attached your cpu fan to your fan controller.
https://linustechtips.com/topic/71832-weird-cpu-cooler-behavior/#findComment-983574
Nope, it's plugged into my motheboard I checked
Maybe it's changing to compensate for the different temperature due to changed airflow in the case.
https://linustechtips.com/topic/71832-weird-cpu-cooler-behavior/#findComment-983579
That would make sense :) But it spins up almost instantly when I turn down my fan controller.
Hmm. Strange.
Also, how would it know that the airflow is changing?
I just mean that it might have been reacting to the change in temperature. The temperature which is caused by the change in airflow, not changing because of the airflow itself.
https://linustechtips.com/topic/71832-weird-cpu-cooler-behavior/#findComment-983616
If your CPU cooler is set to automatically adjust, it will adjust pretty fast. Of course you can check temp monitoring and see how much lower case fan speed effect on CPU tems.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/71832-weird-cpu-cooler-behavior/#findComment-984532
