I have recently gotten my first job at a local fast food joint, and I would like to start planning out my next build.
So far this is what I have in mind: https://pcpartpicker.com/list/mR4Knn
- i5 4590
- XFX RX 470 Triple X OC
- 16gb Crucial Ballistix Sport 1600mhz ram (owned)
- Gigabyte B85M-D3SH
- Cryorig C7 cooler
- 1tb Western Digital Blue 7200rpm (owned)
- 120gb SanDisk SSD (owned)
- Corsair Carbide 88R
- EVGA 600 watt bronze (owned)
I can salvage a lot of parts from my current system (one my dad gave me) so that can cut down costs too. If I were to buy everything new (except an OS, I can transfer the license) it would cost about $800
With the parts I have already, (https://pcpartpicker.com/list/rvZkqk) it costs around $500. Not bad in my opinion. I could ditch the Cryorig C7 since I won't be doing overlcocking, but I don't know.
Or should I just upgrade my current system (https://pcpartpicker.com/list/YZ2tkT)
- FX 6300 OC'd to 4.0ghz
- Zalman CNPS8000B cooler
- GTX 750 Ti FTW
- Asus M5A78L-M/USB3
- 120gb SanDisk SSD
- 1tb WD Blue 7200rpm
- EVGA 600B PSU
- No name generic case
But my old system (FX one) is slowing down a lot, especially noticeable as framedrops in games. I'm not sure if that's the GPU or CPU bottle necking the system.
I play a few AAA games, like Black Ops 3 and Battlefield 1 and Dying Light but I also have my fare share of casual games like Rocket League, L4D2, CS:GO, and Warframe (not really casual but easier on hardware than AAA games)
I get around 55-70fps low on Battlefield 1 and Black Ops 3. In the other games, I can max out settings and get a good 60+. But there are frame drops.
So is it time for a new system all together or for a new GPU? NOTE: resetting my PC did help a bit with frame drops, now they occur about half as often.
**EDIT 1**
So far, drop a case and cooler, go down to H81M, and get a 4gb RX 480
Savings: around $80ish
https://linustechtips.com/topic/718233-first-intel-pc-build/
drop the C7 and get an rx 480 red dragon, the stock cooler is enough for the 4590.
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149021
I've done some research, and I don't see a tangible benefit from upgrading to a RX 480. Especially with the games I'd be playing. I would however get the $200ish XFX RX 480 RS 4gb if I had the money
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149031
the rx 480 would be 20% better in performance compared to the rx 470.
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149049
1 minute ago, herman mcpootis said:
the rx 480 would be 20% better in performance compared to the rx 470,
I'm not gonna deny that, but I really don't have the money
I know I could work a bit longer, but my current PC is degrading. I would ideally like a solution do said degradation or a new PC ASAP
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149051
Just now, Zyndo said:
But you do have the money... you're spending it on other less important places in your system.
What other things could I get rid of?  I
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149068
than why did you get a C7 instead of the stock cooler? dropping it and getting the 480 would save you around $7-9 bucks.
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149070
Just now, CallMeMysterious said:
It's a cheap cooler and a good one
its meant for small form factor cases, not big towers like these. you don't need it too, the stock cooler is good enough.
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149074
@herman mcpootis already told you how: don't get an aftermarket CPU cooler. use the stock cooler. that gives you an extra 30-40 bucks to play around with. easily enough to step up to a 480 4GB of your choice.
You can always buy the C7 (or some other cooler) down the road in a month or two or whenever you have the money. its cheap and easy to throw a CPU cooler in afterwards, whereas upgrading a GPU tends to be quite a bit more expensive as you usually lose a bit of money on the resale value of the old GPU.
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149097
So far, this is what the build is going to look like.
https://pcpartpicker.com/list/8XJsM8
I could even ditch the Carbide case and save another 50 bucks. Sure my current case is a POS, but it can fit a Micro ATX motherboard
without the case, it costs about $470
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149099
You can always buy the C7 down the road in a month or two or whenever you have the money. its cheap and easy to throw a CPU cooler in afterwards, whereas upgrading a GPU tends to be quite a bit more expensive as you usually lose a bit of money on the resale value of the old GPU.
So should I build new and spend $470 or save another $200 and just get a new GPU?
**EDIT** I believe there is a limit on hardware changes in origin though, so maybe just build new
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149108
if you have the money i'd say get the i5 and 480, the fx6300 isn't good for games anymore and the i5 will do much better.
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149119
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.59 @ OutletPC)
Motherboard: MSI B85M-E45 Micro ATX LGA1150 Motherboard  ($52.99 @ B&H)
Video Card: PowerColor Radeon RX 480 4GB Red Dragon Video Card  ($191.99 @ SuperBiiz)
Case: DIYPC J180-W ATX Mid Tower Case  ($39.99 @ Newegg) pretty good case for the money.
Total: $459.56
Generated by PCPartPicker 2017-01-05 20:50 EST-0500
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149132
Total: $459.56
This is personal preference, but I would drop the case, and since my current case has USB 2.0 front, I could even go H81M.
I would like to keep the i5 4590 and I saw the popular youtuber JayzTwoCents make a video on how the 8gb model of the XFX RX 480 was by far the best one he tested so I would go with the 4gb model, worth the $10 more
**EDIT** Here: https://pcpartpicker.com/list/LvD62R
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149155
the XFX rx 480 jay reviewed was the GTR variant, not the RS. they're quite different in terms of performance IIRC. you won't notice much of a difference between the 2 i5s, so i'd recommend you go for the cheaper 4460.
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149176
The amazing one that Jay tested was the XFX RX480 GTR, not the one you put in your list. Just a heads up.
ZamoRIG 2.0:
Processor: AMD Ryzen 7 1700 @ 3.9GHz
Cooling: DeepCool Captain 240 RGB + 2x Corsair ML120 fans
Graphics Card: Gigabyte GTX 1070 G1 Gaming x2
Motherboard: Asrock X370 Gaming K4
RAM: 2x8GB DDR4 G Skill Ripjaws V Grey @ 2800MHz
SSDs: 2xPatriot Ignite M.2 240GB
HDD: WD Black 1TB + WD Green 2TB
 PSU: Corsair RM750
Case: Corsair Carbide 400C
ZamoRIG “Portable”:
Processor: AMD Ryzen 5 1600 @ 4GHz
Cooling: Corsair H80i
Motherboard: Gigabyte AB350N Gaming WiFi
RAM: 1x16GB DDR4 Corsair Vengance  @ 2400MHz
SSD: Patriot Ignite M.2 240GB
HDD: 2TB 2.5” Seagate HDD
PSU: Corsair TX650M
Case: Siverstone SG13
https://linustechtips.com/topic/718233-first-intel-pc-build/#findComment-9149180
