9 hours ago, K352 said:
I know it's hot already but there is this thing called a cooling pad. Any possible ways?
(gs63vr is hotter) I'm planning on using a cooler master U2 plus since it only has 2 bottom intakes and 0 other exhausts for vacuum coolers
so you want to know if a cooling pad can help with the temps on the blade? Well that is a nope. You might get it 1-2c down, but you need to get the blade 15c-20c down. You cannot OC the blade, you have already made a different topic asking if you could. Razer also power throttles the GPU just so the temps don't go batshit crazy after 30sec of game play.
The only laptops that really has any kind of room for OC would be clevo laptops, which are 15.6" or 17.3"laptops
The GS63VR is also cooler than a blade, but no room for OC.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/718105-razer-blade-late-2016-oc/#findComment-9150347
10 hours ago, K352 said:
Snip
Its basically wat @Dackzy said. There is "room"  but it comes to no benefit. You'll get higher firestrike scores but sustained intensive workloads will throttle the blade to whatever the fuck it already was. And because of the retarded hdt heatsink design you can't even liquid metal that shit like you can on macbooks
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/718105-razer-blade-late-2016-oc/#findComment-9150655
