My power 24 pin connector on my computer won't connect to my motherboard no click or anything I have checked for anything in the way of the pins before installing it is the right way as it had gotten this far and I can no longer take out the cable without using so much force that the motherboard starts to bend excessively
I'm the picture it looks like it is cliped in butbit is not
https://linustechtips.com/topic/717290-power-supply-connector/
2 minutes ago, Vishvas Sudarshan said:
I don't think its the gap
I have been told by other people so far I have seen 26 say there should not be a gap in that push until you hear a click,no click
https://linustechtips.com/topic/717290-power-supply-connector/#findComment-9138323
Try trouble shooting other stuff like CPU, GPU power connector.
Whether your RAM, GPU has been Properly installed into their slots.
Whether you've connected the power/reset switches properly (+ve and -ve) etc...
And the connectors at the PSU
https://linustechtips.com/topic/717290-power-supply-connector/#findComment-9138346
The power connector won't even come out of the motherboard for me to test
https://linustechtips.com/topic/717290-power-supply-connector/#findComment-9138390
I have never messed with the power and reset switches at all and it has booted up fine before
https://linustechtips.com/topic/717290-power-supply-connector/#findComment-9138399
Don't just try to pull the connector.
While pressing down on the upper part of the small clip on the connector. Slowly pull and slightly jiggle the connector as your pulling (Don't be harsh on it)
It will come out this way.
But I still highly doubt its your 24-pin connector causing the issue.
But you can give it a try
https://linustechtips.com/topic/717290-power-supply-connector/#findComment-9138413
That is EXACTLY what I am doing I cannot get it to come out and I am already using quite a bit if force
https://linustechtips.com/topic/717290-power-supply-connector/#findComment-9138428
http://www.tomshardware.com/answers/id-1637350/pin-atx-power-cable-clip-motherboard-power-problem.html
http://www.tomshardware.com/answers/id-2626178/pin-cable-contact.html
On that last link a guy posts several links basically saying latch it down
https://linustechtips.com/topic/717290-power-supply-connector/#findComment-9138441
Mine doesn't make a click and doesn't go all the way in, it's still fine. That may not be the problem.
Do you have a modular PSU that you can get a new cable for?
GTX 3080 Ti ROG | Ryzen 5600X | MSI Tomahawk B550 | 32GB 3600MHz | Corsair 850e | HAF X | WD SN850X | Asus MG287Q 1440p 144Hz
https://linustechtips.com/topic/717290-power-supply-connector/#findComment-9138446
Getting a new cable won't make a difference if it won't come out
https://linustechtips.com/topic/717290-power-supply-connector/#findComment-9138454
oh, sorry I misunderstood it.
You could try wedging it out with a thin knife? or in fact just using a knife or some other instrument to cut off the latch/clip on the side.
https://linustechtips.com/topic/717290-power-supply-connector/#findComment-9138491
It looks like the entire thing is bent downwards
https://linustechtips.com/topic/717290-power-supply-connector/#findComment-9138503
So I got it out and this is interesting because it hooks up the the jumper and not the motherboard
https://linustechtips.com/topic/717290-power-supply-connector/#findComment-9138599
