Western Digital are my choice but Seagate are good as well, I wouldn't recommend any others for hard drives.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/71667-memory-help/#findComment-981288
Hey im just wondering what a very reliable HDD is. I will be using it for my raid 0 backup and pictures and stuff.
If your using it for backup use RAID 1, 5, 6 - Stay clear of 0 if backing up precious data.
With regard to drives... Western Digital, personally I would go with RED's.
Gaming System: i7 3770k @4.6GHz, Gigabyte Z77X-UD5H, 8GB Corsair 1600MHz, 2 x MSI GTX 670 PE, Fractal R4, 256GB Crucial M4, Fractal Newton R3 1000W White
Steam Box: Xeon E3 1280 @ 3.5GHz, Intel S1200KP, 8GB Corsair White LP, 1x EVGA GTX 570, Fractal Node 304 White, 64GB Intel SSD, Fractal Tesla R2 650w White
https://linustechtips.com/topic/71667-memory-help/#findComment-981475
Can I use 1 hdd not in raid to back up a raid array?
Ofcourse, as long as it's large enough.
https://linustechtips.com/topic/71667-memory-help/#findComment-981504
I'd suggest against putting SSDs in RAID 0. You're better of running a single big 512GB SSD.
I'm running two 120GB SSDs in RAID 0 myself and I can tell you now that it doesn't make any difference in performance, except for pure sequential R/W, which is completely irrelevant for programs and OS. It even lengthens my boot time significantly because now the RAID controller needs to initialise before the system can boot.
https://linustechtips.com/topic/71667-memory-help/#findComment-986215
