okay but it doesnt really make a difference though because we can on c 29. something?
"on c 29. something"
I started dialing my doctor to get checked for dyslexia,then I noticed that was the actual order of the characters lol.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/7165-radeon-7950-on-eyefinity/#findComment-76319
I would recommend upgrading to / saving up for a 7970. 30fps isnt really playable.
it's not like he will gain much jumping from 7950 to 7970.
c 29?
what game u'll be playing?
https://linustechtips.com/topic/7165-radeon-7950-on-eyefinity/#findComment-76333
Well, you will not get a lot out of getting a 7970, so if you are actually going to save more money, getting two 7950 or 7870 will serve you the best. Having two GPUs splitting the amount of work it has to do to render frames across three displays. If you are thinking about getting a single GPU which will support three displays, at or over 30 fps, try for GTX 690. ( I knew that it is a lot but it is really hard on the GPU to supply adequate numbers of frames to three monitors.) Don't expect to get a lot of frames over three displays using a GPU at a price point under $500 at this point. Running two GPUs will really help.
https://linustechtips.com/topic/7165-radeon-7950-on-eyefinity/#findComment-76560
690 is a dual GPU card.
A 7970 would likely out perform a 690 in eyefinity due to the larger frame buffer.
Eyefinity also works better then Surround in my experience.
I would not go with a 690 for surround. Either a Titan or 2x 4GB 670/680's
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/7165-radeon-7950-on-eyefinity/#findComment-76681
By the way when I said "okay but it doesn't really make a difference though because we can on c 29. something?" I meant - (in long text) Okay but it doesn't really make a difference though because we can not see more than 30.
depend on games, most game feels smoother and less input delay@60fps.
https://linustechtips.com/topic/7165-radeon-7950-on-eyefinity/#findComment-76833
i can see more then 30 most can
https://linustechtips.com/topic/7165-radeon-7950-on-eyefinity/#findComment-76839
I notice a big difference between 30 and 60. I find things don't actually seem smooth until I get 45 fps.
https://linustechtips.com/topic/7165-radeon-7950-on-eyefinity/#findComment-77156
Contrary to what most people might think an HD 7950 can actually drive 3 monitors on most games, I'm not talking about Crysis 3 or Far Cry 3 of course.
But a 7950 can pump out 60+ FPS in Dirt 3, Tomb Raider (high settings, without tressFX), Call of Duty (insert number here), Skyrim (YES there is an eyefinity fix), sleeping dogs etc...
Skyrim Fix : http://www.overclock.net/t/1188893/skyrim-in-eyefinity
https://linustechtips.com/topic/7165-radeon-7950-on-eyefinity/#findComment-77185
The eyefinity fix for skyrim doesn't work on the newest patches for skyrim. You have to be before 1.03 or something stupid for it to actually work. You can get 5760x1080 with no HUD fix to work but the HUD is still screwed.
https://linustechtips.com/topic/7165-radeon-7950-on-eyefinity/#findComment-78034
That's stupid ! , so 9 patches and still no fix for eyefinity ?!
https://linustechtips.com/topic/7165-radeon-7950-on-eyefinity/#findComment-78038
Yeah. its soo annoying. I can get it to work @ 6048x1080. just UI is screwed up and I don't seem to be the only one having a problem. there's a whole topic over at widescreen gaming forum. Because its only a port you can't just adjust an ini file :(
https://linustechtips.com/topic/7165-radeon-7950-on-eyefinity/#findComment-78715
