So i'm building my first PC :). I bought a laptop with gtx 850m 2 Yeats ago because i switch between living with my parents every week and that. But i wanted to try to build a PC with old parts.
I have prebuilt HP with i3-3240 and 4gb ddr3. I got a good psu this christmas but  now i need a good gpu to go with it.
What do you veterans think? Any help will do.
https://linustechtips.com/topic/716220-first-pc-build/
I recommend looking for an RX 460 2GB, GTX 1050 2GB or GTX 1050Ti 4GB (if you can afford it).
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/716220-first-pc-build/#findComment-9126665
RX460, GTX 1050TI or RX470 would all be pretty decent picks for some 1080p lighter gaming, another 4GB of RAM is also nice too have but i havent found that more then 4GB is needed with my LAN PC running with a GTX660, you just dont need it for the titles the card will play most of the time
Builds:
https://linustechtips.com/topic/716220-first-pc-build/#findComment-9126672
What is your budget?
It kinda depends on how much you wanna use, i would rather use a little bit more on the graphics card so it will last you longer, then save money now and have to upgrade in a year or 2.
For instance, people with 980 TI dosent really need to upgrade yet, but the people who bought the cheaper models now have to upgrade. I for once have choosen a GTX 1070, its a little bit more expensive, but it will last me longer.
Main Rig:
CPU: Intel i7 6800k @ 4.2- 4.3 ghz 1.390V CPU Cooler: Corsair H110i GT Motherboard:  Asus x99-E LGA 2011-3 RAM: 32GB DDR4 4 x 8 GB Hyperx Fyru 2133 Mhz Storage: Intel 535 240 GB SSD, Intel 530 240 GB SSD, Seagate Barracuda 2.0 TG SSHD  GPU: Asus GTX 1070 Dual OC cooled by an NZXT G10 & Intel TS13X running @ 1904/2126mhz and 4475mhz Memory+Stock Asus GTX 1070 Dual OC Case: INWin GR One Power Supply: Corsair HX850i Monitor: Hitach 49" 4k lowms TV and a 24 AOC 1080p Monitor Keyboard:  Corasir Vengance K90 & Logitech G13 Speedpad Mouse: Logitech G600 MMO/G602 on an Icemat 2.0 w/glides :P Speakers: LG LAS455H(D8) Soundbar & Logitech G933 Artemis Spectrum Snow Edition Headphones
NAS/CS:GO Server
CPU: AMD FX8320 Stock Cooler: Corsair H100i M otherboard: Asus Sabertooth 990 REV 2.0 RAM: 4x4 GB Corsair Vengance Storage: 2 x Kingston Hyperx 120 GB SSD & 4 X Seagate 2 TB SSHD
GPU: random nvidia 512 mb card PSU: Coolermaster B500 Case: NZXT Phantom S240 Addons: NZXT LXE Fancontrol Intel quad gigabit eterhernet card.
https://linustechtips.com/topic/716220-first-pc-build/#findComment-9126675
Thanks for all the replies!
The problem is that gpu prices in my country is crazy, a rx 480 costs 350+ US dollars. But  older used gpus have less crazy prices. Also my psu is 80+ bronze and 650w corsair so from what i understand it can power almost all gpus. So what good options are there thats older?
https://linustechtips.com/topic/716220-first-pc-build/#findComment-9126763
22 minutes ago, monjessenstein said:
maybe something like an older amd card, considering unlike nvidia amd doesn't abandon their gpu's after a couple of years. If you could get something like a 270,280 or maybe even a 290 that would be great (though do note that they produce a lot of heat)
ok so i shouldn't buy for example a gtx 680 if i can get it cheap and what can i do about the heat if it is a problem?
https://linustechtips.com/topic/716220-first-pc-build/#findComment-9126882
