it depends on the version of windows you have installed, if it is a OEM version, the software is usually tied to the motherboard chipset, so changing that might introduce some problems.
https://linustechtips.com/topic/716157-changing-cpu-mobo/#findComment-9126165
It came with the pre-built system
https://linustechtips.com/topic/716157-changing-cpu-mobo/#findComment-9126296
