34" curved 144mhz gaming monitor
Tedlarsson
Hello, I'm new to the forum and not extremely competent when it comes to monitors. I'm looking for a 34" 144mhz curved monitor to use with my nvidia GTX 960 graphics card. I have a Intel 5 skylake CPU. I am currently looking at the LG 34UC79G-B but it's wondering if there is any other monitors that are equal or better at that 700$ price range? The games I'm playing are rocket league and dota 2. And I'm not considering playing any other games. I'm also considering buying a new graphics card. Either a GTX 1060 6gb or Amd Radeon 480 8gb. So g-sync or free-sync both works.
Edited by Tedlarsson
I would buy one with Freesync so you can eventually enjoy the joys of Adaptive Sync.
https://www.amazon.com/dp/B01CDYB5CW/
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
why you would use freesyng with a nvidia GPU? they dont work with each other i'm right?
you should look for a g-syng monitor and the 34" monitors out there is this one
http://pcpartpicker.com/product/WDcMnQ/acer-monitor-umcx1aa002 but is expensive.
https://www.amazon.com/34-inch-Curved-Monitor-PG348Q-Ultra-Wide/dp/B01C83BE6U
Yeah I edited the text during the time you wrote. I'm also considering upgrading my graphics card. I'm currently choosing between the two models now listed in the original question.
Just now, Tedlarsson said:
Sorry I forgot to mention I wanted a curved monitor.
Cheapest curved is this Dell on B&H
https://www.bhphotovideo.com/c/product/1112687-REG/dell_ultrasharp_u3415w_34_3440x1440.html
I would buy that, and the 480 gains a bit of ground on the 1060 so I would get one of those (the 8GB probably, although on DOTA 2 and Rocket league the 4GB will do fine as well)
Cheapest Freesync is $900 as far as I'm aware, and cheapest Gsync is upwards of $1200, so I wouldn't pay the premium there.
Computer Specs:
The non g-sync version of the acer predator was on newegg for 800 with a discount code for 50 bucks making it 750-- my buddy jumped on that deal. And I just went to newegg to find the link for you-- and they're out of stock I guess http://www.newegg.com/Product/Product.aspx?Item=N82E16824009997&cm_re=acer_ultrawide-_-24-009-997-_-Product
No wonder it's out of stock, that's a really good deal
Computer Specs:
Thanks! I did forget to mention I also want 144mhz refresh rate. But that looks like a great deal! I've updated the original question ??
Freesync monitors work with Nvidia GPUs but the adaptive sync bit doesn't
Computer Specs:
You'll have to do 2560x1080 then. In that case, the 34UC97B you originally posted is the best deal.
Computer Specs:
With these graphics cards you only want 1080p just letting you know if you want 1440p got with a 1070 I'm not sure about the 480 it might run 1440p
PC Build
Ryzen 1800x
Asus Strix 1080ti
G-Skill Trident z RGB 32gb 3200mhz
Gigabyte K7 motherboard
NZXT Kraken x62
EVGA Supernova P2 850w
Phanteks Enthoo Evolv ATX TG
SAMSUNG 960 EVO M.2 1tb
Seagate Barracuda 3tb
Gigabyte WiFi and Bluetooth Card
x3 NZXT Aer RGB Fans
NZXT Hue
Yeah I have come to terms with the fact that I will have to be happy with 1080p at my budget level. But thanks for the heads up!
http://www.webhallen.com/se-sv/datorer_och_tillbehor/253638-acer_predator_z321q-32-4ms-hdmi_dp-144hz-g-sync-curved&atcl=search:result
I am considering this monitor also. It's 32" so I lose the ultra wide aspect ratio but I can live with a huge 16:9 ratio I think. The site is Swedish but the specs and info is in English. Anyone got some thoughts about it?
