I recently bought 4 enermax magmas from frys electronics. i was just wondering if i should use them for my case fans or on a rad (240mm) in push pull
CASE: deepcool dukase v2 MOTHERBOARD: Gigabyte gaming 3 CPU: intel core i5 6500 GPU: Gigabyte gtx 1070 g1 gaming CPU COOLER: enermax liqmax II 120s SSD: Kingston ssdnow uv400 240gb RAM: crucial ballistic sport (1 x 8) PSU: Cooler Master GX 650W
https://linustechtips.com/topic/714956-radiator-fans/
They are pressure fans so they would work decent for radiators and areas where there is airflow restriction.
https://linustechtips.com/topic/714956-radiator-fans/#findComment-9114853
lol wow such lies on the specs on those fans no way they are 20dba at max speed when noctua's and other top end fans are closer to 30dba.  They might be ok as case fans, but I wouldn't expect much from them.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/714956-radiator-fans/#findComment-9114858
thanks i think there gonna look good in my red themed build
https://linustechtips.com/topic/714956-radiator-fans/#findComment-9114870
yeah I'm guessing they are cheap fans? They'll probably be ok but won't stack up to the more expensive high end fans.
https://linustechtips.com/topic/714956-radiator-fans/#findComment-9114915
yeah i got them for $12 at fry's electronics but they seemed good for there price.
https://linustechtips.com/topic/714956-radiator-fans/#findComment-9114929
this is the 1500rpm variant, but I doubt you'll be running them higher than that anyways
http://www.anandtech.com/show/6391/120mm-radiator-fan-roundup-part-2-fan-harder/6
strap them on that rad!
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/714956-radiator-fans/#findComment-9115300
