Hey Guys!
I want to get some speakers for about 50€ for gaming/watching videos/listening to music. And since I don't really know much about audio products, I need your help. Should I get an amp and some bookshelf speakers or something like a 2.1 sound system? What would your recommend?
Thanks for your help!
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/714671-budget-speakers-help/
look used....
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/714671-budget-speakers-help/#findComment-9112937
What do you think about the Logitech Z333 or the Hercules XPS 2.1 bassboost @Dackzy?
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/714671-budget-speakers-help/#findComment-9126467
I think no thanks. Logitech is low quality and the "subwoofers" that come with either of those two aren't really subwoofers.
I would still recommend buying used, there is nothing wrong with buying speakers used, it is not like the tech in speakers evolve very fast and they often have a long lifespand. Also a 2.0 setup can with no problem have more and better bass, than either of those 2.1 setups.
If you don't want to buy used, then I would recommend saving up another 50€ and get some Edifier Studio 1280T
https://linustechtips.com/topic/714671-budget-speakers-help/#findComment-9126496
Thanks! But I rly don't know much about speakers.:( Can you give me some examples for what I should look for?
Main PC:
Dorm PC:
NAS:
Laptop:
https://linustechtips.com/topic/714671-budget-speakers-help/#findComment-9126502
Well I would start with looking at brands you have heard of before and start with only active speakers (one of them has a power input), since a passive speaker would need a amp and 50€ is a very small budget, so IMO active would make more sense. You could start with Edifier and Behringer they have generally had some decent budget systems, but remeber look up reviews and such.
https://linustechtips.com/topic/714671-budget-speakers-help/#findComment-9126521
the Logitech z333 don't look too bad with a more proper cabinet design, and a woofer and tweeter.
but sound, idk...
https://linustechtips.com/topic/714671-budget-speakers-help/#findComment-9127016
but sound, idk...
The sound isn't good
https://linustechtips.com/topic/714671-budget-speakers-help/#findComment-9127048
I would guess better than other Logitech, but again, all based on looks.
https://linustechtips.com/topic/714671-budget-speakers-help/#findComment-9127113
