Hi Guys
Lately I've been playing Far Cry Primal and Battlefield 1. And sometimes when i open either of these games and start playing on high/ultra settings at 1080p, then all I can get is  15-30FPS. If i then restart my PC and the games a couple of times, the problem solves itself and I will be able to play at a steady 60+ FPS without changing any settings at all, only restarting the system. Been using both FRAPS and Uplay to monitor FPS.
CPU Temp: Max 70
CPU Usage: 48%
Memory Usage: 78%
GPU Temp:Max 63
Does anyone know what causes this issue? And please let me know if you need any more information
My PC build:
Cpu: i5-4690k
Gpu: R9 390
Mobo: MSI Krait
Ram: 8GB DDR3 HyperX
Thanks in advance, help is much appreciated since it's very annoying of having this "Restart Ritual" everytime i want to play :P
https://linustechtips.com/topic/714587-low-fps/
Have you overclocked your GPU? Try installing MSI Afterburner and monitor your clock speeds to see if they suddenly get stuck at a low frequency.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/714587-low-fps/#findComment-9111127
37 minutes ago, elert said:
Hi Guys
CPU Temp: Max 70
CPU Usage: 48%
Memory Usage: 78%
GPU Temp:Max 63
My PC build:
Cpu: i5-4690k
Gpu: R9 390
Mobo: MSI Krait
You're only a few degrees celsius from the system to auto shut off to prevent damage due to thermal throttling. Try to clean out your PC and make sure there is enough room for air to flow freely through. Also, is your system water cooled? If not, you're probably getting more high temperatures through the CPU because you overclocked it (that is if you did take advantage of it being overclockable) :/
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
https://linustechtips.com/topic/714587-low-fps/#findComment-9111131
Thanks for your response guys. None of my components are overclocked and although my cpu temp is high and i need a better aftermarket cpu cooler, I dont think the issue is caused by a heat issue. The problem occurs even when I have just turned on the PC and gone directly into the game - and therfore, haven't had any time to heat up at all. Also wouldn't a heat issue cause crashes and errors rather than just limiting my fps?
https://linustechtips.com/topic/714587-low-fps/#findComment-9111163
Well what can happen is that your GPU get's put under too much stress and it will puth itself in safe mode, limiting the clock speed. If you are not overclocking I can't tell you why, but you should at least check you clock speed to see whether that is happening.
My System:
https://linustechtips.com/topic/714587-low-fps/#findComment-9111172
