QSo I'm building my first gaming PC and i have the part list and everything, but i need to know if my PSU is big enough to handle my GPU and CPU being overclocked.
https://pcpartpicker.com/user/Fahrenheit/saved/RFFzK8
CPU Intel Core-I5 6600K OC to 4.4GHz MOBO MSI Z170A Gaming Pro Carbon RAM 16GB Kingston HyperX Savage DDR4-2400MHz GPU Gigabyte GTX 1060 G1 Gaming 6GB
Cooler Cooler Master Hyper212 Evo PSU Corsair RM650x 650W Boot drive Kingston v300 120GB SSD Storage WD Blue 1TB 7200rpm HDD Case Corsair Carbide Spec-03
Extra NZXT Hue+ LED light controller + 2xNZXT Aer 120mm RGB fans
https://linustechtips.com/topic/714007-a-quick-question-about-a-power-supply/
http://outervision.com/power-supply-calculator
CPU: intel core i5 6600K Motherboard: gigabyte GA-Z170M gaming 5 RAM: 16Gb corsair vengance LPX 3200 GPU: gigabyte R9-390x  Case: thermaltake v31
Storage: m.2 256 gb samsung 850 evo, m.2 500gb samsung 850 evo,  4tb segate barracuda PSU: thermaltake toughpower 850w gold
Display: ASUS VC239H 23in Widescreen Eyecare LED Gaming Monitor Cooling: Deepcool malestorm 240 Keyboard: Tt eSPORTS POSEIDON Z RGB
Mouse: Cougar 700m Sound: Logitech Z906 THX 5.1 OS: Windows 10
Easily.  You could fit a 6700K and SLI on a 650W psu.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
Well I don't have money for that, but this is gonna be good enough to hold the 6600k and a 1060 overclocked right?
8 minutes ago, PCGeek said:
Yeah you're good.
I also have the NZXT Hue kit, that won't be a problem?
Way more than enough.
You could probably run that on a good 400 watt power supply (although that would not be recommended).
More than enough.
Do yourself a favour and switch out the Cooler Master Hyper 212 EVO for the CRYORIG M9i or H7. You'll skip the pain associated with mounting it on the socket.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
10 minutes ago, HKZeroFive said:
More than enough.
Not available in my country
Alright, I suppose it will suffice.
5 hours ago, Ramke_99 said:
No
Good PSU choice, but I'm going to swap things around as you could do better for your money. Here you go.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.88 @ OutletPC)
Motherboard: MSI Z170A GAMING PRO CARBON ATX LGA1151 Motherboard  ($147.99 @ NCIX US)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  ($69.99 @ Newegg)
Storage: ADATA Ultimate SU800 128GB 2.5" Solid State Drive  ($44.99 @ Amazon)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Amazon)
Video Card: PNY GeForce GTX 1060 6GB 6GB Video Card  ($246.39 @ SuperBiiz)
Case: Fractal Design Define S w/Window ATX Mid Tower Case  ($64.99 @ NCIX US)
Power Supply: Rosewill 550W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($74.99 @ Newegg Marketplace)
Total: $1053.20
Generated by PCPartPicker 2016-12-29 12:24 EST-0500
Got you an i7, a better cooler, better SSD, cheaper HDD (for storage it doesn't really matter that much), better case, PSU that's a little bit worse but is still way more than good enough for a 1060, a cheaper 1060, and it all still fits your color scheme.
32 minutes ago, STRMfrmXMN said:
No
Total: $1053.20
That won't work for me cause a lot of those parts are unavailable or overpriced here
Ahh, gotcha.
