Picture Quality
Solved by GoodBytes,
Well it's a bit hard to see as not only you scaled the image down, but you compressed it at super low jpeg quality.
Start > type: Color Management > Enter.
Check the box: Use my setting for this device
Then click on Add button, and then select sRGB virtual device profile profile. Then click on OK, then close the panel.
Now, restart Windows Photo gallery.
Is the picture better?
Featured Topics
Gat Pelsinger ·
Posted in Linux, macOS and Everything Not-Windows0 -
1
Sai125943 ·
2
eric_s ·
Posted in Troubleshooting2 -
Bublito ·
Posted in Troubleshooting3 -
3
1
7
Siamshot ·
Posted in New Builds and Planning2
