2 hours ago, JmessGaming said:
Can I use the same product key twice if I bought a disc version of windows 10, which I used on another older computer. but I want to build a new computer so can I use the same product key/ disc.
AFAIK, the product key is tied to the "original" computer's BIOS, and even if you somehow transferred the key, it would *probably* be deactivated on the first computer.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/712290-same-product-key-twice/#findComment-9088792
You don't buy windows, you buy a license to run windows, which is tied up to the Personal Computer you first install it, there a few ways to try transferring it though, however if its one of those Windows that comes with a brand new laptop you bought from the internet then it will always only work on that machine regardless.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/712290-same-product-key-twice/#findComment-9088798
so I have a old laptop I never use with windows seven can I use that product key n the new computer
https://linustechtips.com/topic/712290-same-product-key-twice/#findComment-9088853
Like I just said, no you can not, laptop original included OS have their license locked to their motherboard and can not be transferred.
Personal Desktop":
https://linustechtips.com/topic/712290-same-product-key-twice/#findComment-9088922
this is untrue. OEM licences can be used on any board and any system as long as the machine the key came from is dead or disassembled. You may have to contact MS, but it will usually result in a reactivation.
idk
https://linustechtips.com/topic/712290-same-product-key-twice/#findComment-9088964
